2017 TDV6 ZF8 Transmission Fluid Change
Old Apr 26, 2024 | 09:18 PM
gmfain's Avatar
Default 2017 TDV6 ZF8 Transmission Fluid Change
I finally got to do the fluid change.
Level rig up. Ramps or jack stands.
Kit from FCP Euro. They shorted me 1 liter, didn't need but 5 anyway.
belly pan has 8 15mm bolts. I also loosened the 4 front belly pan bolts, because this pan slide under the front pan.
Belly pan removed, looks like original tranny pan.
8mm hex drain plug, passenger side.
Pan removed, and cleaned and ready for new one.
New pan installed. 8Nm torque, I'll post the torque pattern.
Magnet in old pan
Magnet in old pan
old pan
Full instruction here. https://www.fcpeuro.com/blog/how-to-...d-transmission
My notes: I filled until drizzled out. Started truck, held brake, went through gears, R-N-D-S, it would only allow S1, S2, S3...........waited till temp reached 45C
With truck still running, pulled fill plug, finish topping it off.
shut it down, checked for leaks, performed reset:
0. Press "Start" button only. (ie: Do NOT start the engine.)
1. Press and hold gas pedal to floor for approx. 15secs.
2. Press "Start" button again.
3. Release gas pedal.
4. Wait approx. 2mins.; start engine and drive.
She is smooth as Butter!
Old Apr 26, 2024 | 09:22 PM
adam5's Avatar
well done, and thank you as always for sharing your expertise!
Old Apr 27, 2024 | 12:49 PM
bkjecu94's Avatar
You can only drain what drains and there will always be residual of the old fluid, correct? Looks so easy via pictures! (Famous last words.....). Thank you for sharing.
Old Apr 28, 2024 | 12:04 AM
ar077's Avatar
I notice that you have Lucky8 rock sliders (as do I). The rock sliders can support the vehicle and I use my Hi-Lift jack with an adapter (
Amazon Amazon
) to lift either side of the vehicle. I'm thinking that jack stands positioned at the four corners of the rock sliders could support the vehicle with the wheels off the ground, which would facilitate cycling through the gears without having to apply the brakes after changing transmission fluid. Comments?
Old Apr 28, 2024 | 03:42 PM
gmfain's Avatar
Yes, that is what I gathered also. It sems to be 2/3's I recon.
Old Apr 28, 2024 | 03:46 PM
gmfain's Avatar
Originally Posted by ar077
I notice that you have Lucky8 rock sliders (as do I). The rock sliders can support the vehicle and I use my Hi-Lift jack with an adapter ( https://www.amazon.com/dp/B00F4HX9FW...language=en_US) to lift either side of the vehicle. I'm thinking that jack stands positioned at the four corners of the rock sliders could support the vehicle with the wheels off the ground, which would facilitate cycling through the gears without having to apply the brakes after changing transmission fluid. Comments?
Yes, @Lucky8Sean rock sliders. They will hold the weight.
I thought about the four jack stands also. I was just not brave enough to try it.
If you try that method, let us know how it goes.
Old Apr 30, 2024 | 09:59 AM
1979rover's Avatar
Are those reset steps just for the transmission or for the service light?
Old Apr 30, 2024 | 12:38 PM
gmfain's Avatar
Transmission Reset/Relearn.
Old May 8, 2024 | 10:53 AM
rnmcguire's Avatar
Nice thanks for sharing I need to do mine soon!
Old Oct 2, 2025 | 06:25 PM
LR disco 5's Avatar
Magnet in old pan
Magnet in old pan
old pan
What mileage was this done at?? im currently at 145k km.
