Adding Overland Lights / Power access
All-
I have had an LR4 for years, and have just upgraded to a 2020 D5 HSE Lux. I am working on adding some front grill Overland lights and have realized unlike my LR4 the D5 has the battery in the rear. Assume there is some smart way to connect to 12v in the front, but wanted to know if anyone on the forums has already been down this road before I make wasted time.
Searched and did not find much that would answer what I am looking for. Pictures would be great!
Thanks
Drew
Thanks
Drew
Apparently there is a power block behind the wheel liner on the front passenger side wheel liner ( referring to LHD there. Driver side for RHD) this can be used for lights, winch, etc. It has extra terminals already to add accessories. No pictures of this yet since I have not started my winch install.
Thx.
The lamps are Baja Designs - S2 - 2450 lumens ea. Look closely they’re mounted upside down on the license mounting frame - Amazon - (black aluminum), quite rigid and doesn’t vibrate. No cutting into the grill. The wiring is snaked past the fan housing to the take off + post and - ground. Controlled wirelessly. No cutting into vehicle’s wiring and voiding any warranty leftover. Just make sure you shut off - wirelessly. It works great.
1979rover (03-21-2022)
I did not get a chance to pull the wheel liner this past weekend due to installing the LR camera system. Once I receive the rest of my order from LKY8 with the A bar I am planning on pulling the front end and will snap a picture then. Hopefully this coming up weekend as I would like to have everything ready for SCARR in 2 weeks.
