-   New Discovery V (https://landroverforums.com/forum/new-discovery-v-51/)
-   -   Anyone ever changed the transfer case fluid? (https://landroverforums.com/forum/new-discovery-v-51/anyone-ever-changed-transfer-case-fluid-109834/)
AirRyan Dec 29, 2021 07:51 AM
I bought some Ravenol fluids to change the fluids in all of my diffs and transfer case. Only 20k miles but wanted to do the rear diff sooner. A lot of gunk on that magnetic drain plug and it's a good idea that it gets changed sooner to get rid of those break-in metals.
On my twin speed transfer case, I'm not certain of the fluid capacity. Can anyone confirm the capacity? I thought initially it was 2L from some service bulletins I have read, but I believe as I have come to find out that the capacity is only 1.5L, which would make more sense given the amount I was able to get back in.
Also, I apparently had the incorrect p/n's on the plugs for the transfer case; they were ever so slightly smaller. IYB5000020 is what I was told and what I have, but they seem like they are the plugs for perhaps the smaller single-speed transfer case.
https://cimg0.ibsrv.net/gimg/landrov...9a279131ae.jpg
AirRyan Dec 29, 2021 05:24 PM
Castrol shows 1.5L as does Kroon Oil in NL. Mine took a wee bit under that to refill so 1.5L makes much more sense. I didn't get 2L's worth out, that is for sure. Thought it was going to need to take 2L as some LR literature I have says (my local LR parts counter, as well,) but I took the fill plug out again this morning and it was dripping, so I did another pump or two and put it back together. The plugs I have for the transfer case are either the wrong plugs in both P/N bags or LR has their P/N's wrong. IYB5000020. New plugs I bought to use were ever so slightly smaller.
https://rego2oil.castrol.com/en_au/a...4x4_2016_2021_
https://www.kroon-oil.com/en/product...ponent:650838/
Here is the pic from the drain plug on the front diff. Lots of break-in gunk on it. Easy to do.
https://cimg2.ibsrv.net/gimg/landrov...8f38caab8.jpeg
ponderosajack Dec 29, 2021 08:23 PM
I am ready to change mine soon. Bought 2 liters but expect to only fill 1.5. Doesn’t matter as you fill until it spills out. What does matter is the fluid you use. For the differentials a quality 75w90 synthetic is specified. But for the transfer case there’s no aftermarket spec. Just the LR fluid and it’s been upgraded from the LR3 LR fluid part number.
Considering the transfer case probably costs over $6k if you could even buy one I wasn’t willing to save $50 on fluid.
AirRyan Dec 30, 2021 09:21 AM
8 Attachment(s)
I like Ravenol products because they publish their specs and they have a premium line (gold bottles) that uses the best base stocks available, (poly-alpha-olefin, or PAO.) Rarely will you find a comparable product with superior specs. Look at the pour and flashpoints to get a good indicator as to the quality of the base stock.
  • If you have the electronic locking rear differential (service manual calls it the Electronic Torque Managed or ETM diff), you need Castrol BOT 720 spec. 1.21L wet capacity. LR p/n is LR019727.
    • Both diffs use the same drain and fill plugs. One each for each diff. TYB500060 is the fill plug (6mm hex) and TYB500110 is the magnetic drain plug. (I used the square 3/8's extension.
  • The transfer case fluid spec is DTF-1 which is actually a BMW spec. LR p/n is IYK500010. I believe the capacity is 1.5L as I didn't even quite get all that amount in. I put in just about exactly what I got out.
    • Uses two plugs that use a small copper washer and a 6mm hex. I was told, I ordered, and my local LR dealer confirmed that IYB500020 is the part number. The ones that I received were a tad too small and would not fit. I had to reuse my existing plugs.
  • The front differential uses the regular Castrol SAF-XO 75w/90 gear oil. Only takes 0.51L. LR p/n is TYK500010
https://cimg3.ibsrv.net/gimg/landrov...903de48df8.jpg
LR Max Jan 3, 2022 08:20 AM
3 Attachment(s)
I've changed the fluids.
-Rear locking diff had a bit of sludge on the magnet plug but not that bad (changed at 32k, no hard driving). Rear locking diff...eh, wasn't bad fluid but I wasn't convinced it would be good until 60k. I just re-used the plugs. I also used OEM fluids from the dealer (I think for rear locking diff, I have to).
-Front fluid at 32k looked new. Definitely could go until 60k. Front fluid is same fluid as in the LR3/LR4 front diff. Which is nice because I gave my left overs away.
-T-case. Yeah it hold about 1.5L but I'll tell you what, FUDGE THE GUY WHO DESIGNED THAT FILL HOLE. Its like refilling DEF, slow and miserable. First off, remove the little heat shield around the fill hole. I just removed 2 of the 3 lower bolts. Top bolt of the shield, I loosened and then moved the shield out of the way. Drained the fluid (once again, looked fine for 32k, can easily bump to 60k change). Refill sucked. I got a hand pump for the job. Main issue is that you gotta STICK the pipe in there at a weird angle. You'll see, there is a plate right behind the fill hole. You'll end up spilling fluid everywhere if you try to refill fast.
See attached information I have on D5 fluids (pre-ingenium engines) and T-case info.
maviaman Dec 31, 2024 09:51 AM
Hi, I have a 2017 First Edition ..how to determine if it has a rear dynamically ( Which I suspect it got) locking diff? thanks
CincyRovers Dec 31, 2024 10:10 AM
Go to the 4x4i screen and if it has a lock over the rear diff, you have the rear locking diff. If you only see the lock over the center diff, you do not have the rear locker.
maviaman Dec 31, 2024 10:32 AM
thanks! yeah just have one locker over the transfer case....
gmfain Jan 1, 2025 12:12 AM
https://landroverforums.com/forum/ne...change-117195/
Wingman6 Feb 1, 2025 12:47 AM
Funny you mention the crush washers for this job. I got my fluid and washer from the dealer and mine too were too small. I ended up just reusing the one from the car but might be something weird with that they have in their system.
