Brembo big brake upgrade for Td6 Discovery
I first saw this on a FB page in a Discovery 5 FB group, apparently, this is a relatively popular upgrade going back to earlier Discovery's, as well. I got the calipers on Ebay, advertised "like-new" in the aspect that they were certainly new, old-stock, just not in any sort of original packaging or what not. One of them wasn't packaged very well and it showed when it arrived, so I decided to paint them with VHT caliper paint which they say is supposed to be good up to 900°F. In retrospect, I would just suggest that make sure you allocate plenty of time to properly mask off and paint your calipers, before attempting to install them. It's a lot easier when they are new and off the vehicle.
Now my truck had just 750 miles on the odometer, so I really didn't need new screws for the splash shields or even the rotor bolt was fine to reuse. I expected to replace the washers on the banjo nut on the brake line, but the washers on my banjo nut looked better than the copper washers I had ready to replace, so I just reused them. The splash shields are the same ones that the petrol or gas D5's get, and are rather exorbitantly overpriced if you're coming from a diesel Td6, but I really wouldn't not want to have them there. I used new caliper bolts as that is what JLR says to do, (TTY) but the ones that I took out looked fine. Notice that the correct torque spec for D5 caliper bolts is 100 ft.lbs. + 60°. My advice, turn your wheels on each side all the way so you have as much access to those caliper bolts, so you can get as long of a breaker bar on those bolts to get them off.
The calipers are genuine Brembo with Land Rover stamped on them. Looks better and when those big front Brembo's clamp down, the truck just stops. I also swapped the rear pads real quick before I did the fronts, with the same Power Stop Z36 line (1692) for the rear, to eliminate all brake dust. A thin 17mm wrench here will help a lot. The LR service procedure for putting the electronic parking brake in service mode was easy to use and worked well. Otherwise easy as pie to swap the rear pads.
The following 3 users liked this post by AirRyan:
I just noticed that there is indeed separate LR part #'s for the wear indicators, although I just used a zip tie to help hold the wire in place on the new Brembo caliper. Per Y/T videos, it looks like the wear indicator for the Brembo caliper has a rubber grommet that goes around the inside bleeder valve.
https://www.landrovermerriamparts.co...-on-dash-panel
Brembo brake upgrade on Land Rover Discovery 3 and 4
Atlantic British video on Brembo rebuild kit on a 2014 RRS - these are essentially the exact same front brakes at least; excellent video
1979rover (06-09-2020)
Is there any reason you couldn't go with a new pair of Speedmaster calipers? 6 piston, look to be pretty decent especially at this price point.
https://www.carid.com/speedmaster/sp...vehicle=116500
I had not looked into something like that but those specific ones would not work. They only work up to 330mm and the upgraded rotors are 380mm. Plus if I'm patient enough I'm confident I can get the brembos for around $1,000 anyway. It's just weird that there are a number of left front calipers available but no right front.... weird....
Hi Seattle TD6,
I did my brembo upgrade on my 2014 D4, that upgrade includes Calipers, Rotors, splash guards and one wear sensor wire. I am about to buy a 2017 D5 which came with a 4 piston brake, of course I would like to do the same brake upgrade, appreciate if you can share the sources of all components with me , Many thanks.
I retained the Brembo from my D4, it looks the same like what AirRyan posted, unfortunately the part number differ ( LR 016661 vs LR 039524 ), well I guess I will have to buy another pair of calipers then.,
