Discovery 5 lift kit by Johnson Rods
Old Jan 19, 2019 | 01:26 PM
Johnson Rods's Avatar
LR Forum Vendor
Default Discovery 5 lift kit by Johnson Rods
Our Johnson Rod 1.5 inch lift kit for the Discovery 5 has been a very popular upgrade. Since we introduced the kit in Mid 2017, it has been a favorite around the world with hundreds of satisfied customers. With the lift, the ride and feel remains excellent and our customer feedback is very positive for both on and off the road. The 1.5 inch lift will give you additional ground clearance to run trails faster in normal mode. Then when needed, switch to off road mode for added clearance. This lift will allow a larger off road tire such as a 275-55-20.
Many Land Rover dealers use our lift in their showrooms as seen below in an upgrade package. Our lift is preferred because of the quality of construction and materials that can stand up to extreme hot and cold conditions without breaking down. We use 3/16 high quality stainless steel which provides strength and durability. Our rubber attachment points are extra thick just like the original Land Rover part which insures a tight non slip connection and which makes them less susceptible to cracking and breaking down under harsh conditions. In fact, the rubber has a high resilience and tensile strength, abrasion resistance and operates effectively in temperatures between -60 degrees F to 180 degrees F.
What is amazing is how much this lift and a set of AT/MT tires enhances the overall look of the vehicle.
Here are a few dealer pics with 275-55-20 Goodyear Dura Tracs.
See more at: JohnsonRods.com
Follow us on Instagram: @johnsonrods
Discovery 5 with 1.5 inch Johnson Rod lift and 275-55-50 Dura Trac MT tires
__________________
Please visit our website: https://www.Johnsonrods.com
Visit our vendor section:Johnson Rods Vendor
Old Jan 19, 2019 | 02:27 PM
BchBum11511's Avatar
This is a body lift I assume?
Old Feb 4, 2019 | 05:11 PM
LR Forum Vendor
Default Discovery 5 lift kit #johnsonrods
The BFG KO2 tire has been one of the most popular brands for those looking for an All Terrain tire.
There are many good brands out there as we show on our tire size chart on the website. Here is a great example of our 1.5 inch lift and the BFG KO2 275-55-20 AT tires.
We are always looking for feedback on tires so if you have a brand you really like let us know how its performing.
Feel free to text us a pic to post at 760-625-5519 with information about your rig upgrades, wheels and tires.
Discovery 5 with 1.5 inch Johnson Rod lift 275-55-20 BFG KO2 AT tires
__________________
Old Feb 27, 2019 | 11:55 AM
LR Forum Vendor
Rather than going to the expense of getting new wheels, we have seen many users opting to powder coat their stock wheels black or in the case of the picture below, desert sand.
The rig below is running Falken Wild Peak AT 275/55/20.
Discovery 5 with 1.5 inch Johnson Rod lift, 275-55-20 Falcon Wild Peat AT tires
__________________
Old Mar 6, 2020 | 03:07 PM
LR Forum Vendor
Our 1.5 inch lift is the sweet spot for lifting the D5 and provides the best overall driving feel.
This is why our kit is used by Land Rover dealers and independent Land Rover shops around the world.
Check our website for more details.
1.5 inch Johnson Rod lift kit
__________________
Old Mar 30, 2020 | 06:42 PM
LR Forum Vendor
When it comes to reliability and quality our Johnson Rod Discovery 5 lift kit is the top choice of Land Rover dealers.
The best materials, the best connection points and the superior ride quality with a 1.5 inch lift.
Check out our website and follow us on Instagram with the links below.
D5 towing 7,000 pound travel trailer with Johnson Rod lift
__________________
Old Jul 16, 2020 | 01:54 PM
LR Forum Vendor
Default Discover 5 lift kit
Time to get ready for summer trails...
1.5 inch lift with 275-55-20 tires
__________________
Old Aug 6, 2020 | 01:36 PM
LR Forum Vendor
Another dealer installed Johnson Rod lift on this Discovery 5.
Ask your Land Rover dealer to install Johnson Rods on your new Discovery.
Check our website link in the signature below:
__________________
Old Aug 20, 2020 | 12:35 PM
LR Forum Vendor
The BFG KO2's look great on this Discovery using our 1.5 inch lift.
Click on our website link below for more:
__________________
Old Sep 23, 2020 | 12:20 PM
runNride's Avatar
Are there any photos of LR5s in the low/normal/road position with these lift kits?
