The 2004 Land Rover Discovery I own was sold to me by an dishonest person. Within weeks the car started to overheat, blow steam/smoke out of the engine, leak multiple fluids, and not run well. How much do you think it would be to fix all these problems?
https://cimg4.ibsrv.net/gimg/landrov...e8e61f686.jpeg The back of the car has lowered significantly? Any causes? There are these blue suspension bags that appear to be deflated?? |
With the info given it's impossible to answer your how much question. The rear appears to have Air Suspension that has deflated. When the vehicle is running the air compressor will kick on and reinflate the system. It is not uncommon for them to sink when sitting for a time. Obviously with your description above I wouldn't recommend idling the truck to see if it comes up.
What's your coolant level look like and what fluids are leaking? |
(Post 792521)
Stick a fork in it. You'll spend more $$ than you want on it and than it is worth, way more. Sell it and get a Honda or Toyota. Sorry. Hope you didn't pay much. How many miles??
Fyi, It is a 2004 Land Rover Discovery Series II, not a Series I. |
Is it insured ? Shhhhhh - it was stolen or it caught fire
Originally Posted by Buddy101
(Post 792525)
My coolant disappears. The owner told me to top up with water when it goes down... The coolant hose not good either. Oil and a reddish liquid also leak
Redish is either trans, power steering or ACE |
Originally Posted by disco96sd
(Post 792829)
(Post 792843)
So you knew it was loosing coolant, is it all coming out leaking or blown hoses?
Originally Posted by stillruns
(Post 792527)
If you got it for the price of the car without an engine I don’t think the seller was dishonest. He told you about the coolant leak. If you want to keep your Disco it sounds like it needs a lot of work. As said above maybe you should sell it, again for the price of the car without an engine.
