newbee
Hi I'm looking to buy a 01 disco series 2 its very clean 1 owner and has 110k.I'm not a machanic but have done my fair share of renching on cars and suvs.like I said this disco is very clean sound shifts and drives solid if I can just get some more advice on any particular issues that I should be looking for I would be greatfule thanks.....
see https://landroverforums.com/forum/di...scovery-21328/
borrow or rent an OBDII scanner and plug in to check for stored codes and burned out check engine light. Scanner is even better as it will show temps. Above 50% on heat gauge is hot to trot. No ticking sound when warmed up, no sludge or mayonaise on inside of oil cap or coolant cap. |
Thanks will use the scanner today....
nice to meet u:p
Greetings to the forum. Lots of great guys and gals on here with a wealth of infomation. Use the search tab above for questions as you not the first to come across a problem with a Land Rover product... Enjoy the frustration and joy that comes with owning a classic British vehicle and dont forget to download a copy of the RAVE, work shop manual.
__________________ |
