Series 3 1-Tonne Transfer Box - Overdrive?
Hi
I own a 1975 Norwegian ex-military Series 3 109. It happens to have a 1-tonne transfer case on it, which doesn't exactly provide a blistering top speed.
I have been looking around at overdrive units, but the ones I have been able to find so far aren't compatible with the 1-tonne transfer case. Are there any that are?
There's a serial number on the gearboxes.
Here's a forum that will help you identify if you have a real 1-ton, but it sounds like you might.
http://900club.19.forumer.com/viewfo...0990ec40a323d3
If you were here in the states I'd swap you a gearbox setup, I want a 1-ton setup.
I ton gearbox and transfer
I too have an ex-Norwegian Army 1975 Series III, 109 diesel with a 1 ton gearbox and transfer case. It came with the candy wrappers still inside, sat in a field for 8 years. I bought it and drive it almost daily. It is really slow, but has a lot of power. I am interested in swapping out the entire gear/trans for a series 3 std unit. Anybody interested? I'm in Maine, USA
Disco_Fever
10-14-2009 09:56 PM
