2011 Range Rover Supercharged
Old 06-29-2017, 11:23 AM
Szybki's Avatar
6th Gear
Default 2011 Range Rover Supercharged
Hi Guys
I need your help. I own a 2011 RRS and for the last year I am trying to fix up the issue with the car. I live in Virgin Island so I am limited to a professional Range Rover service.
My car won't start sometimes It will crank but won`t start. This happens on occasions. I can drive the car with no issues for few days and out of the blue it will not start or the engine will stop during the drive. No dashboard warning light I have scanned the computer and no error either. I have already replaced:
1. Fuel pump
2. Fuel module
3. Cam shaft sensor
4. Fuel relay
5. Fuel pressure sensor
6. Crank position sensor
If you have any other ideas what could be the issue please help I am desperate. I love my car and I want to keep if for few more years.
Thanks
Old 08-12-2017, 09:09 PM
Shadow993's Avatar
What codes are you getting?
Old 08-13-2017, 06:46 AM
Szybki's Avatar
6th Gear
Hi
At the begging the only thing that the computer was able to detect was the fuel pump assembly. I have purchased of market brand. It helped for a while but then again back to my issue. I have now purchased an original Land Rover fuel pump assembly (waiting for it to arrive) as i have heard that this might be the problem. Do you know if there is any adjustment to the new pump after installation or everything should work fine by just putting it in.
Thank you for your feedback!!!!!!!!!!!!!
Old 08-13-2017, 08:33 AM
Shadow993's Avatar
No adjustments that I'm aware of on the pump. The fuel pumps in the motor are timed to the motor, and that's how it controls pressure.
Have you given the throttle body a good scrubbing and cleaned the sensor on top of it?
My dad's was getting weird acceleration, not starting a few times, and going in limp mode. He had codes all over the place. After cleaning the mafs , throttle body, and that sensor, the issue disappeared.
I have an XFR with the same motor, and they have a faulty fuel pump problem recall.
https://www.google.com/amp/www.autob...tial-fuel-sta/
Check to see if Range Rover has the same problem.
Old 08-14-2017, 10:23 AM
Szybki's Avatar
6th Gear
Thank very much for this information I will pass it on to the mechanic. Hope this helps
Regards
Old 08-21-2017, 09:55 AM
Szybki's Avatar
6th Gear
Hi Shadow993
So i have purchased an original fuel pump and original cover and new harness for it also new fuel relay.
And it didn't help. Car is still shutting of from time to time. The mechanics here are not familiar with this issue so Im just throwing money out the window here. If you have any other suggestions what my cause this please let me know. Some people are saying i need to change my spark plugs, wires and clean crankshaft position sensor. ( i got new sensor installed so its not it.) Few people say to change my coil as it might be clogged.
I also got new fuel module installed all part are original LAND ROVER.
Old 08-21-2017, 11:11 AM
Shadow993's Avatar
What codes?
Have you cleaned the heck out of your throttle body and the sensor on top of it?
In the past stalling was caused by carbon/dirt/ oil build up on the throttle body. I veli be there is a pin size hole in the bottom that gets clogged. If it's like the one on my jag XFR
Clean that and your mass airflow sensors with the proper cleaner
Old 08-21-2017, 02:30 PM
Szybki's Avatar
6th Gear
No codes. I will tell them to clean the throttle body but i think they already did it in the past. I will address the mass airflow sensors as that might be the issue.
I have read the the fuel injectors might be faulty but i would loose power if one of them was not working right?
Old 08-21-2017, 04:21 PM
Shadow993's Avatar
Right... if it was a coil or injector , you would definitely get a code.
A misfire code or a lean code.
Hook up a Bluetooth code reader... then you can watch it live. So when it starts giving you trouble their might be a pending code.
I had a misfire that wouldn't throw the CEL, but showed as pending on occasion.
lucyf0rd (09-17-2017)
jmeyers278
01-04-2017 08:27 PM
1985mb
07-31-2014 04:22 PM
allwood2006
01-28-2012 08:42 PM
asmithcash4real
ROAMING WITH FRIENDS
07-04-2011 07:27 PM
dr.brillo
06-08-2011 06:29 PM
Quick Reply: 2011 Range Rover Supercharged
