Good question. That’s a lot of miles. Presumably a California car would be rust free so that’s in its favour. RRC’s in good condition are worth some money.
If you can get a better deal then yes I would 100% fix and keep.
So far it's not passing smog, and the bags have failed so it's on bump stops (not drivable).
I have a suspicion it needs head gaskets, but don't have the car so can't do proper testing. Owner took it to a shop to try and get it to smog. They did plugs and wires and said the compression test came back "very good". (I'm shocked that a reputable shop would not test for exhaust gas in the coolant, or pressure test the cooling system on a Rover -- known for head gasket problems). So with potentially bad head gaskets and blown bags, it's really more of a project than I want right now. But I still made him an offer at a price that would make sense. I.e. subtract likely costs to repair these items. Stay tuned... |
Aaaaand the owner accepted my offer and I just took possession of it last night.
Now for some investigation! |
What's the update on this?
Originally Posted by swissarmychainsaw
(Post 872644)
I have a suspicion it needs head gaskets, but don't have the car so can't do proper testing. Owner took it to a shop to try and get it to smog. They did plugs and wires and said the compression test came back "very good". (I'm shocked that a reputable shop would not test for exhaust gas in the coolant, or pressure test the cooling system on a Rover -- known for head gasket problems). |
Originally Posted by mbruneaux
(Post 879124)
I rebuilt the air suspension, and did a thread on RangeRovers.net: https://www.rangerovers.net/threads/...2#post-2428188 I did that first so I could move it around and get it to the smog inspection. And then I went after the smog and idle issues https://www.rangerovers.net/threads/...5#post-2427789 The summary is: new fuel injectors got it to pass smog. My smog tech guy suggested this fix! Exhaust leak fix helped it to run less rough (smog guy again for the win) |
Sounding great. Please keep us updated.
:nopics:
| All times are GMT -5. The time now is 01:33 AM. |
