RH Rear Door issues
RH Rear Door issues
Hi,
My passenger rear door has some intermittent faults, not sure if common or an easy common fix.
The rear window and lock just stop working at the same time for a while and then come back to life, but the time it is all dead is getting longer and can be days before any power to the lock or the window, the lock seems ok, if the car is locked you can use the door outer handle to unlock the car and also lock the car with the sensor, but does not lock that door.
Hope there is some help for this.
Regards
Tony
Regards
Tony
