Terrain Response & Suspension issues
I have a 2008 LR RR HSE w/120K miles.My front end is lower than usual and will not raise up. It bouncy when I hit small bumps.When I start it up, the Terrain Response is in normal mode (Special Programs Off), On-Road Indicator is lit, and the High Range is lit. After about 30 seconds the Terrain normal & On-Road indicator lights go out, but the High Range light stays lit. When this occurs I can’t make any changes to the Terrain Response. I have no clue as to why it is doing this. Help!!
Sequence of events1) 1st Start2) After 1st Start #13) 3 Minutes after Idle4) After 2nd Start #15) After 2nd Start #2 https://cimg8.ibsrv.net/gimg/landrov...1cc8abf2e9.jpg 1st Start https://cimg1.ibsrv.net/gimg/landrov...c0c501599a.jpg After 1st Start https://cimg5.ibsrv.net/gimg/landrov...821a0d1075.jpg After a 3-minute Idle https://cimg4.ibsrv.net/gimg/landrov...10865bdb06.jpg After 2nd Start #1 https://cimg3.ibsrv.net/gimg/landrov...904f86466f.jpg After 2nd Start #2 https://cimg0.ibsrv.net/gimg/landrov...e6f765c0e1.jpg https://cimg9.ibsrv.net/gimg/landrov...7f3904c13e.jpg https://cimg8.ibsrv.net/gimg/landrov...21333207c9.jpg |
Looks like you have an EAS fault and it is shutting down systems as a limp limp effort.
If it is isolated to the front. It could be an airline, valve block height sensor or spring. To better diagnos the issue a Land Rover specific tool to pull codes is needed |
Thanks Dude!
I really appreciate the quick reply. |
