Thumping noise from rear suspension
I have a 2017 Range Rover Autobiography LWB with 23,000 miles. There is a thumping noise that occurs only when you drive the vehicle after it is garaged overnight or not used for several hours. It will make a noise that sounds like a basketball bouncing in the rear of vehicle only for about ten seconds and then not again during that drive. Dealer could not locate any mechanical suspension issues while vehicle was on lift. I have confirmed that if the vehicle runs in garage for five minutes before driving it will not make this sound. Could this be a problem with one of the rear air shocks?
I have a 2017 Range Rover Autobiography LWB that has the exact same noise as you described by Quickserv.
I really appreciate if you help me to understand what was the issue and how did you resolve it?
Hopefully it is not the differential.
Regards,
Regards,
