Range Rover P38 (2nd Gen) Talk about the Land Rover Range Rover P38 within.
Torque converter not locking up
Old Apr 13, 2025 | 08:09 AM
Default Torque converter not locking up
Ok so I have all 4 gears and the trans is shifting smoothly. Now that it’s rolling smooth and aligned I got out and was cruising at 70 down the interstate and noticed the torque converter is not locking up. Where do I need to start with diagnosis on this one.
I have a code for the transfer case but I am not seeing anything for the transmission when I pull codes.
I’ll pull codes again when I get to the shop to see if I missed something or we have a new one.
Old Apr 13, 2025 | 09:23 AM
Harvlr's Avatar
And presumably the engine and transmission are fully warmed up? I don’t think it locks until fully warm. Maybe it’s not sensing it’s target temp?
Old Apr 13, 2025 | 02:01 PM
Yup fully warmed up temp sensor reporting around 188-190 cruising down the highway on the live data
Old Apr 15, 2025 | 07:19 AM
I am seeing a transfer case fault of
TRANSFER BOX LINK - SIGNAL LINE PERMANENTLY AT 12V OR OPEN CIRCUIT (DRIVING CYCLE A)
I cannot get the launch tool to connect to the trans ECM if it actually has one. It always comes up with a communications fault
Old Apr 16, 2025 | 02:47 PM
Harvlr's Avatar
It definitely has one. IIRC under the drivers seat. Maybe try unplugging it and spraying the connectors with electro cleaner?
Old Apr 16, 2025 | 09:05 PM
Awesome will check under there tomorrow.
Old Apr 19, 2025 | 05:32 PM
Finally got under there and the connector was clean and fully seated unfortunately. I ordered a good used one will give it a shot.
Old Apr 20, 2025 | 10:13 AM
Harvlr's Avatar
Hopefully that works. Did you try it after disconnecting and reconnecting?
Old Apr 20, 2025 | 04:09 PM
Absolutely did however it didn’t make any change
Was contemplating resetting adaptive values to see what happened out of curiosity
Old Apr 25, 2025 | 12:21 PM
So new to me module showed up, it does shift better but still no torque converter lock up. I did try switching to sport mode and noticed the truck wouldn’t down shift and basically drove like crap with either ecu. I wonder if that switch has an issue that’s causing a problem?
None of my code readers can do the trans adaptive value reset on it. I’m not 100% positive that is a thing with the 1997 model year
ahab
Mar 13, 2025 06:22 PM
danyboyGA
Feb 5, 2024 03:51 PM
miron
Aug 7, 2023 07:54 PM
cobbcj7
Apr 12, 2014 06:57 PM
elrocha69
Jan 16, 2012 06:50 AM
