07 rr sport what is recommended thicker oil?
Burns 2 quarts in 4000 miles what is a recommended thicker oil? Currently, using 5w-30 semi blend. |
Don't know that there is a recommended thicker oil. If you have the owners manual you can check in the fluid specifications section. I also think it recommends full synthetic oil.
Is it burning it or leaking oil? |
Burning
It is burning it. This chart below says semi blend https://rimmerbros.com/PopUp--id-444 |
Oil
I run all my rivers on 15-40 rotella truck oil always had always will I ran my disco to 190 k and my 2nd disco has 205 k my range rover sport has 160 k none of these cars ever lost or burned any oil and I would change it at 15 thousand miles
Two very different motors, 15w40 would likely grenade the 4.4 Jag
(Post 679096)
Last longer?
