Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
07 rr sport what is recommended thicker oil?
Old Jan 21, 2019 | 09:31 AM
mstarkoil's Avatar
Default 07 rr sport what is recommended thicker oil?
Burns 2 quarts in 4000 miles what is a recommended thicker oil? Currently, using 5w-30 semi blend.
Old Jan 21, 2019 | 11:27 AM
Don't know that there is a recommended thicker oil. If you have the owners manual you can check in the fluid specifications section. I also think it recommends full synthetic oil.
Is it burning it or leaking oil?
Old Jan 21, 2019 | 01:08 PM
mstarkoil's Avatar
Default Burning
It is burning it. This chart below says semi blend
https://rimmerbros.com/PopUp--id-444
Old Feb 3, 2019 | 10:47 PM
earnies2's Avatar
Default Oil
I run all my rivers on 15-40 rotella truck oil always had always will I ran my disco to 190 k and my 2nd disco has 205 k my range rover sport has 160 k none of these cars ever lost or burned any oil and I would change it at 15 thousand miles
Old Feb 4, 2019 | 09:01 AM
Two very different motors, 15w40 would likely grenade the 4.4 Jag
Old Feb 5, 2019 | 07:47 AM
earnies2's Avatar
I run 15/40 in my sport and I have 159 k on it been using it for years it runs cleaner and lasts longer. There is no technical reason why you can't run 15/40
Old Feb 5, 2019 | 02:28 PM
Last longer?
cgray11
Dec 31, 2014 09:16 AM
tyguru
Apr 24, 2012 09:30 AM
mdfud
Jul 24, 2010 10:12 PM
robk1313
Jul 21, 2008 12:58 PM
doeboy
Sep 10, 2005 08:07 PM
