HDC system fault,park brake fault,system shutting down
Hi All
I am having an on going battle with my Sport. Started a few weeks ago after a tyre change.(now have matching tyres) It started with the orange/yellow warning light (vehicle tilt when cornering) its has since escalated to park break fault,hdc fault system shutting down. It can be ok then for no apparent reason it kicks off. I have changed battery,park break switch under stearing wheel,brake bulbs and topped up the fluid. On my 4x4 display when in access mode the rear right sensor line is showing red - CAN this cause these problems? Also I have some internal foot well light bulbs out (waiting for replacement) - Can this be a cause? Below are the codes it throws at me. Any help[ where to look please. Car Scanner ELM OBD2 DTC report Selected brand: Land Rover VIN: SALLSAA139A193806 ============1============== U0010(88) Raw code: C01088 ECU: 60 Status: Test failed (current drive cycle), Pending, Test failed since last DTC clear OBDII: Controller area network (CAN) data bus, medium speed bus ============2============== U0122(87) Raw code: C12287 ECU: 32 Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear OBDII: Data bus, vehicle dynamics control module - no communication ============3============== U0416(86) Raw code: C41686 ECU: 2B Status: Test failed (current drive cycle), Pending, Test failed since last DTC clear OBDII: Invalid data received - vehicle dynamics control module ============4============== C1A55(64) Raw code: 5A5564 ECU: 2A Status: Test failed, Test failed (current drive cycle), Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle, Warning indicator requested ============5============== U0416(94) Raw code: C41694 ECU: 1C Status: Test failed, Test failed (current drive cycle), Pending, Test failed since last DTC clear OBDII: Invalid data received - vehicle dynamics control module ============6============== U0155(87) Raw code: C15587 ECU: 19 Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear OBDII: Data bus, instrumentation control module - no communication ============7============== U0155(87) Raw code: C15587 ECU: 18 Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear OBDII: Data bus, instrumentation control module - no communication ============8============== P1623(00) Raw code: 162300 ECU: 10 Status: Pending, Test failed since last DTC clear, Test not completed during this operation cycle OBDII: Immobilizer Code Word/ID Number Write Failure |
Did you solve this issue because I have the same
Originally Posted by millermagic
(Post 741773)
Hi All
I am having an on going battle with my Sport. Started a few weeks ago after a tyre change.(now have matching tyres) It started with the orange/yellow warning light (vehicle tilt when cornering) its has since escalated to park break fault,hdc fault system shutting down. It can be ok then for no apparent reason it kicks off. I have changed battery,park break switch under stearing wheel,brake bulbs and topped up the fluid. On my 4x4 display when in access mode the rear right sensor line is showing red - CAN this cause these problems? Also I have some internal foot well light bulbs out (waiting for replacement) - Can this be a cause? Below are the codes it throws at me. Any help[ where to look please. [color=#201f1e]Car Scanner ELM OBD2 DTC report Selected brand: Land Rover VIN: SALLSAA139A193806 ============1============== U0010(88) Raw code: C01088 ECU: 60 Status: Test failed (current drive cycle), Pending, Test failed since last DTC clear OBDII: Controller area network (CAN) data bus, medium speed bus ============2============== U0122(87) Raw code: C12287 ECU: 32 Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear OBDII: Data bus, vehicle dynamics control module - no communication ============3============== U0416(86) Raw code: C41686 ECU: 2B Status: Test failed (current drive cycle), Pending, Test failed since last DTC clear OBDII: Invalid data received - vehicle dynamics control module ============4============== C1A55(64) Raw code: 5A5564 ECU: 2A Status: Test failed, Test failed (current drive cycle), Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle, Warning indicator requested ============5============== U0416(94) Raw code: C41694 ECU: 1C Status: Test failed, Test failed (current drive cycle), Pending, Test failed since last DTC clear OBDII: Invalid data received - vehicle dynamics control module ============6============== U0155(87) Raw code: C15587 ECU: 19 Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear OBDII: Data bus, instrumentation control module - no communication ============7============== U0155(87) Raw code: C15587 ECU: 18 Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear OBDII: Data bus, instrumentation control module - no communication ============8============== P1623(00) Raw code: 162300 ECU: 10 Status: Pending, Test failed since last DTC clear, Test not completed during this operation cycle OBDII: Immobilizer Code Word/ID Number Write Failure Did you solve this issue because I have the same??? |
