Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
HDC system fault,park brake fault,system shutting down
Old Sep 3, 2020 | 09:03 AM
millermagic's Avatar
3rd Gear
Angry HDC system fault,park brake fault,system shutting down
Hi All
I am having an on going battle with my Sport.
Started a few weeks ago after a tyre change.(now have matching tyres)
It started with the orange/yellow warning light (vehicle tilt when cornering) its has since escalated to park break fault,hdc fault system shutting down.
It can be ok then for no apparent reason it kicks off.
I have changed battery,park break switch under stearing wheel,brake bulbs and topped up the fluid.
On my 4x4 display when in access mode the rear right sensor line is showing red - CAN this cause these problems?
Also I have some internal foot well light bulbs out (waiting for replacement) - Can this be a cause?
Below are the codes it throws at me.
Any help[ where to look please.
Car Scanner ELM OBD2
DTC report
Selected brand: Land Rover
VIN: SALLSAA139A193806
============1==============
U0010(88)
Raw code: C01088
ECU: 60
Status: Test failed (current drive cycle), Pending, Test failed since last DTC clear
OBDII: Controller area network (CAN) data bus, medium speed bus
============2==============
U0122(87)
Raw code: C12287
ECU: 32
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear
OBDII: Data bus, vehicle dynamics control module - no communication
============3==============
U0416(86)
Raw code: C41686
ECU: 2B
OBDII: Invalid data received - vehicle dynamics control module
============4==============
C1A55(64)
Raw code: 5A5564
ECU: 2A
Status: Test failed, Test failed (current drive cycle), Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle, Warning indicator requested
============5==============
U0416(94)
Raw code: C41694
ECU: 1C
Status: Test failed, Test failed (current drive cycle), Pending, Test failed since last DTC clear
============6==============
U0155(87)
Raw code: C15587
ECU: 19
OBDII: Data bus, instrumentation control module - no communication
============7==============
U0155(87)
Raw code: C15587
ECU: 18
============8==============
P1623(00)
Raw code: 162300
ECU: 10
Status: Pending, Test failed since last DTC clear, Test not completed during this operation cycle
OBDII: Immobilizer Code Word/ID Number Write Failure
Old May 28, 2023 | 07:36 AM
Thestig888888's Avatar
Default Did you solve this issue because I have the same
Originally Posted by millermagic
Hi All
[color=#201f1e]Car Scanner ELM OBD2
DTC report
U0010(88)
Raw code: C01088
ECU: 60
U0122(87)
Raw code: C12287
ECU: 32
U0416(86)
Raw code: C41686
ECU: 2B
C1A55(64)
Raw code: 5A5564
ECU: 2A
U0416(94)
Raw code: C41694
ECU: 1C
U0155(87)
Raw code: C15587
ECU: 19
U0155(87)
Raw code: C15587
ECU: 18
P1623(00)
Raw code: 162300
ECU: 10
Did you solve this issue because I have the same???
okdiscoguy
Jan 16, 2024 04:31 PM
