20155 RRS HSE V6 Coolant Leaking
Hi, Sorry, new to the forum and hoping someone can shed some light on the situation.
I brought the truck to the dealer this morning due to low coolant warning and the smell of burning antifreeze.
They said the water pump bearings are wearing and it's leaking slightly. They will replace under warranty. Here's the kick.
They said there are 2 hoses leaking as well, and require that the top of the motor be removed along with the supercharger in order to get to the hoses.
The hoses are about $600 and the total cost including labor $2,200
I think I'm getting hosed. No pun intended.
Are there hoses that require the entire top of the motor to be removed? Seems a bit extreme.
Thanks
Thanks
Thanks
Thanks
First they said 2 pipes+ the waterpump were leaking, then said the front pipe is cracked and the water pump leaking. They want to replace the rear pipe for preventative measures.
He's using a screwdriver to pry up the pipe from the block. He sent me a video but does not appear to be any leaking from where they said it is.
I'm generally skeptical about such things as well, but in this case, preventatively replacing the rear pipe is a really good idea. I've read many accounts of LR4 owners being left stranded in the middle of nowhere with a blown rear pipe, and even worse, not noticing the engine overheating until it's overheated to the point of destruction, and now you're looking at a new engine.
That being said, it could be done probably way cheaper at an indy shop rather than a dealer. Dealers charge about 2x the price of indy shops.
57,000 miles. My warranty ran out at 50,000 but the CPO extended runs longer which is why the Waterpump was covered.
My complaint is the tech said it's completely ruptured and gushing fluid. He has refused to do a pressure test.
I know how dealer mechanics get paid, so I fear they are using scare tactics to get me to do work that is unnecessary. I really don't want the supercharger and manifold removed if I can avoid it. Once you open that up, I'll probably have other problems.
The front coolant pipes travel under the supercharged, no way around to do the coolant pipes without removal of the supercharger. There were 3 superseded part numbers due to design flaw. The water pump has a small black tube behind with 2 seals that should always be replaced when removed/replaced.
I took the car out of service today. They replaced the water pump. Now the truck overheats when the AC is running. If the car is just sitting at idle, no AC running the temp never exceeds 1/2 on the gauge.
No loss of coolant. I'll run a pressure test to see if there are any leaks, but can't find anything obvious.
Does anyone have any ideas?
