Range Rover Sport L494 (2013-present) Talk about the Land Rover Range Rover Sport within.
Possible sensor harness
Old Nov 12, 2021 | 10:13 AM
Rapide's Avatar
Default Possible sensor harness
Hi all,
New member here. I am fairly mechanical (I restore old motorcycles) but have not messed much with my 2014 RRS, so please forgive my ignorance. My main battery died and I replaced it myself. However, I noticed a wiring harness with coupling on the right side of the wheel well which doesn't appear to have a home. I disconnected and reconnected the sensor on the negative terminal, but I cannot see an equivalent female to attach the right-sided harness to and do not believe it was hooked to anything before I removed the battery. It consists of only 2 wires, a black/white and a brown/white. Is it ok to leave this disconnected? Is it there for an accessory I do not own or is it essential to connect it to someplace I haven't found ? The car runs fine. The only electrical side effect of changing the battery is that I appear to have lost the fully-up function of my window switch (I need to keep lifting the switch to completely close the windows).
I'd appreciate any wisdom from you experts and thank you in anticipation.
Paul.
Ben Ledbetter
Mar 31, 2021 12:35 PM
Ataylor88888
Aug 16, 2020 04:45 PM
whowa004
Jul 17, 2020 06:25 AM
emt2976
Jul 3, 2014 07:52 PM
