Series I, II, IIa, III Land Rovers For all Series Land Rovers
1961 series 2
Old 09-23-2019 | 08:03 PM
ihscouts's Avatar
That is the rebuild kit, look at Rovahfarm, not quite half way down the page; https://rovahfarm.com/seriesbrakespage1.htm
And congrats man, you can't believe how much I was grinning seeing you picked up a SII. PT would be like the second coming......
Old 09-25-2019 | 08:13 PM
TOM R's Avatar
5hanks scouts, gonna try to rebuild that master with the kit in the truck Hopefully it works, also ordered a fuel pump rebuild kit today
Old 09-25-2019 | 08:43 PM
TOM R's Avatar
So i dont have a key for that ignition , is there a way to re key it
Old 10-03-2019 | 08:29 AM
The Deputy's Avatar
Probably wouldn't be too hard to bypass, by pulling down the dash panel.
Congratulations, on the purchase. Darn cool machine.
Brian.
Old 10-03-2019 | 04:48 PM
TOM R's Avatar
Itnis by passed, need a key so i can set it up right
Old 11-11-2019 | 06:19 PM
TOM R's Avatar
Finally did some work on this today, i swapped out the clutch master and brake master , still need to put in the new clutch slave and then bleed everything
How do u bleed these since i saw no way to bench bleed off the car
The new clutch master looks same as old one but the new
brake master is bigger
Old 11-11-2019 | 06:27 PM
Brakes will be bleed at the wheel cylinders
Bleed for the clutch should be down at the the clutch slave cylinder
This is from memory so I could be wrong
Old 11-12-2019 | 04:55 PM
TOM R's Avatar
I kind of figured all that lol, just a time thing
Old 11-12-2019 | 08:17 PM
Well you asked
Old 02-13-2020 | 06:43 PM
wrongway's Avatar
6th Gear
So wheres the best place to look for parts for series 11 109s ?
Quick Reply: 1961 series 2
