Jacked in the rear? :( 2"lift
#21
#22
#23
#24
#25
At least you know what is going on. Not sure how thick the spacer is that you have back there but you could do similar in front. But then you need to consider the driveshaft and other issues. I have installed the same kit on mine but added spacers in both front and rear along with driveshaft, brake lines and rerouted ABS cables.
#27
#29
You can buy aluminum spacers for about $45-60 ? > Suspension Lift Spacers - 1 Inch - Rear (Pair)
OR, if you really want to make a set of ANY SIZE you want for less than about $30.00 go here > https://www.onlinemetals.com/
They will cut small lots of any material including aluminum cheap.
#30
Greg Vasileff (11-30-2017)
