Videos of users in their Rovers OFFROAD ONLY
We all want to see videos of our fellow users in action, so I'll try and get the ball rolling with this.... 22DIRTY OFFROAD
also here is the most recent picture with a modded front bumper..
I'm running 33's, 1inch lift in rear, 2inch lift in front, no cdl(yet!!).
Please keep it ROVIN' and REPLY BACK WITH VIDEO...!!
From July 2nd on Jenny Creek trail in Colorado. The water was so high from the snow melt that it was overflowing the banks all over the place:
YouTube - ‪Jenny Creek compilation 7 1 2011 v2‬‏
As far as specs:
1994 Disco, stock 3.9L, stock R380 5-speed, LT230 from a Defender 110 (1.41:1 high range) with Maxi Drive 4.34:1 low range crawler gears
Axles- Stock housings stuffed with ARB lockers f-n-r (at the moment, the front has a stock 3rd due to the ARB creating metal flake), factory 3.54 gears, rear Maxi Drive HD axle shafts and drive flanges, front Rovertracks LongTracks HD CV shafts
Suspension- RTE RR4-3 and RR1-3 3" lift springs, Rock Ware rear trailing arms, BilleTTech front 3" lift radius arms, Rock Ware extended rear upper shock mounts and modified lower rear mounts, D2 front shock towers modified (by me) for 1/2" hardware, homemade (by me) lower front eye mounts, Fox emulsion shocks f-n-r: rear 12" valved to 90/100, front 11" valved to 85/95 all with ORW polyurethane bushings (got rid of those spherical bushings - too noisy and some got loose and sloppy quick)
Wheels and Tires- warm wx: 255/85-16 BFG MT KMs on NATO steel rims; cold wx: 265/75-16 Goodyear MTRs on factory castor alloy rims (so that chains clear the body)
Winch- Warn M10000 with 150' of 3/8" steel cable; Winch Saver line weight. I have synthetic 3/8" line to go on when I get around to it.
Other Modifications- Skid plates front to back (steering, catalytic converters, transmission/transfer case, frame sliders, fuel tank, pinion guards - most are Rock Ware), crappy sliders/nerf bars, ARB front bumper, unknown-make custom rear bumper and rear quarter protection, Mantec snorkel, in-cab throttle control mounted on center console, Tom Woods double cardan driveshafts f-n-r, Rock Ware offset tie rod and drag link
I think that covers it. I've pushed it enough that I don't have a straight panel on it anymore. The original/previous owner would likely cry if he saw it.
From my first time out with my truck and the club i went with, NELRC
http://www.youtube.com/embed/iUa7iY5OYik
wont let me embed this but ^ is the link
Another one. I managed to damage my windshield mount, so there's more pics than video in this one. But, I'll throw it out there anyways. Yes, in late July some trails are still blocked by snow here.
‪Trail Run July 23, 2011‬‏ - YouTube
