Suspension sponsored by Arnott Inc. Talk about your suspension within.
new to land rovers and wanna lift it!!!!!
Old Feb 11, 2013 | 11:15 AM
antichrist's Avatar
People have mixed results with a 3" lift. Some have no issues, some have bad steering geometry problems and need other modifications. If you're just using it off-road you shouldn't have any issues, other than maybe brake flex line shortness. You can fit the lift and then check if they are ok using a jack.
hilltoppersx's Avatar
Originally Posted by robertmirwin
Anyway back to the lift. Is it correct that i can go 3" and only have to change my springs and shock?
thanks for all the input
robert
yup. only other things you might want to do is get some extended brake lines and pop the abs sensors out of their holders so they have more play. also ditch the sway bar up front and you are good to go!
Old Oct 25, 2013 | 10:48 AM
CUpgt's Avatar
While 3" is possible with just shocks and springs I would suggest supporting mods. Radius arms are not a must but are very nice. Trailing arms will be huge for offroad performance. You will probably need a double cardin front drive shift and adjustable panhard bar. You don't have to do it all at once but they make the end result much better. My lift is probably closer to 4" with RTE 3" springs though. Brake lines are a must if you plan on articulating at all.
Pwoens
Aug 25, 2019 09:59 AM
DiscoPhipps78
Dec 8, 2012 01:36 PM
RenoHuskerDu
Oct 16, 2011 08:28 AM
snwbrd
Feb 26, 2006 06:44 PM
mikemeyer0
Off Topic
May 27, 2005 01:56 PM
