Rancho x vs. Ome ltr vs. everything
Rancho 9000x vs. OME LTR which one is better Vs. any other brand or model you can come u with
Also Rover tym vs. ome springs
i have disco 1 97' 235/85/16 bfg mt andexcept for having to replace almost everything under the hood except the engine its pretty much stock i would like to get at least a 2 inch lift post your opinions thanks warren
RE: Rancho x vs. Ome ltr vs. everything
If the brake lines haven't been done I would get new ones as well.
If you stick with 2 inches that's about all I would worry about.
If you go to 3" then I would add along list to that.
I have 3" OME and blistein I have been vary happy with the set up. I've been doing quite a bit of upgrading along the way with axles drop towers in the front drop mounts in the rear new trailing arms etc....
ranchos are no good
pro comps are no good
ome ltrs are a waste of money because theyre not long enough
non ltr ome shocks and yellow bilsteins are good if you stay under 3"
koni shocks are good but expensive
bilstein 7100s and fox 2.0 shocks are nice but expensive
i like rovertym springs over ome springs. dont really know why.
if you lift under 3", all youll need are the springs and shocks. extended brake lines depending on shock choice. if you go over 3" youll need lots more. go to http://www.rovertym.com/ and see what theyve got and give them a call and see what he recommends.
im currently running rovertym 3" springs w/ 1" spacer, bilstein 7100 shocks, and spring retainers in the rear and im very happy with it.
Buddy Lee
03-31-2014 10:39 AM
My98disco
08-02-2005 12:33 AM
