Tires What skins are you rollin' around on? Discuss wrapping your rims in here.
20" RR wheels on a 05 LR3 SE
Old Aug 29, 2007 | 12:05 PM
Kooner's Avatar
8th Gear
Default 20" RR wheels on a 05 LR3 SE
I was looking at installing 20" x 8.5 Range Rover wheels with 5.75 bolt pattern on my 2005 LR3 SE. Currently, I have the stock 18" wheels with a 120 bolt pattern. Does anyone know if I would be able to fit the 20" rims on my LR3? Would I need new lug nuts or anything else? I'm not sure if the bolt pattern would work or the offset. Also, what would be the biggest tire I could put on the 20" without it rubbing? Thanks
Old Aug 30, 2007 | 05:48 PM
Default RE: 20" RR wheels on a 05 LR3 SE
Do you realize your truck will ride like crap with 20" wheels, it will be like drive a cattle truck. Give it a real serious thought and try something smaller.
Old Aug 30, 2007 | 06:49 PM
Kooner's Avatar
8th Gear
How would the 19" RR wheels be? I just don't like the look of the 18" LR3 SE and its hard to get a hold of 19" LR3 HSE wheels.
Old Aug 31, 2007 | 09:00 PM
19's are better and between the different Rover forums classified sections, I have seen 19's out there for sale.
Old Sep 1, 2007 | 12:11 AM
dirtyduk's Avatar
Range Rover wheels dont fit LR3s, if I remember right , the hubs centers or lugs are a different size, tried it for another guy.It cant be done !
Old Sep 4, 2007 | 11:53 AM
Jantiz's Avatar
Whichever wheel you end up using, I'd advice listening to Mike. 20" or bigger makes for a rough ride on the LR3. I wouldn't go over 19 if you are dead set on Low Pro look. I sold my HSE 19" and bought 18's to put on mine. I couldn't have made a better move.
Old Dec 13, 2024 | 02:46 PM
LandRuler's Avatar
6th Gear
Wouldn't it be more dependent on sidewall height and air pressure rather than the size of the wheels?
nh9095
Jan 14, 2019 12:36 AM
Vincent@CEC
Mar 9, 2011 05:08 PM
Kooner
Aug 28, 2007 04:51 PM
disco12
Feb 14, 2006 11:35 PM
