Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Brand Reviews > Appearance
Register Forgot Password?
Old 06-12-2007, 03:39 PM
Junior Member
Default Body corrosion
I have got a 1998 Discovery tdi with a lot of patches of corrosion on the body,especially on the wheel arches.
How do i treat it,and do i need to treat up behind the wheel arches.
Also the wheels are corroding too,and need treating as soon as i can.
Chris
Old 07-27-2007, 11:59 PM
Junior Member
Default RE: Body corrosion
im in auto collision right now.
if its just rust bubbles you just take lets say a 40 grit sandpaper and sand all the rust off about 3 inches past the corrosion area. then use a 3m brand body filler if needed. prime and paint. do not mask around the area for priming. it makes hardlines which make for hard sanding when you paint it.
this is the only correct way to fix rust without making it worse.
Old 08-02-2007, 04:21 PM
Junior Member
Thanks for your help,Do I need an Etch Primer on Alluminium panels?
Chris
Tags
body, corrosion, land, rover
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
