Appearance & Camping Set Ups Talk about your interior and exterior mods including camping and rooftop camper set ups here.
Body corrosion
Old Jun 12, 2007 | 03:39 PM
chris's Avatar
3rd Gear
Default Body corrosion
I have got a 1998 Discovery tdi with a lot of patches of corrosion on the body,especially on the wheel arches.
How do i treat it,and do i need to treat up behind the wheel arches.
Also the wheels are corroding too,and need treating as soon as i can.
Chris
Old Jul 27, 2007 | 11:59 PM
lowzq8's Avatar
3rd Gear
Default RE: Body corrosion
im in auto collision right now.
if its just rust bubbles you just take lets say a 40 grit sandpaper and sand all the rust off about 3 inches past the corrosion area. then use a 3m brand body filler if needed. prime and paint. do not mask around the area for priming. it makes hardlines which make for hard sanding when you paint it.
this is the only correct way to fix rust without making it worse.
Old Aug 2, 2007 | 04:21 PM
chris's Avatar
3rd Gear
Thanks for your help,Do I need an Etch Primer on Alluminium panels?
Chris
mpcrnc
Nov 17, 2013 05:54 PM
99LRDisc
Oct 14, 2008 01:31 AM
jofnui
Mar 7, 2008 06:45 PM
N.Franklin
Nov 2, 2007 01:13 AM
howellja
Apr 29, 2007 10:52 PM
