Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
wiring loom
Old Apr 21, 2005 | 06:01 PM
sheenalandi's Avatar
4th Gear
Default wiring loom
how involved is it to make a wiring loom. i have all the diagrams butwhat cable do i use etc. surley its better to buy 1 but it is 4 a mate an he cant afford it!!
Old Apr 21, 2005 | 06:35 PM
mikemeyer0's Avatar
Default RE: wiring loom
what are you trying to make?
Old Apr 23, 2005 | 11:10 AM
4th Gear
i have been asked to mke the entire wiring system!!
Old Apr 27, 2005 | 04:26 PM
4th Gear
it is for a series 2 long wheel base
Old Apr 27, 2005 | 04:32 PM
mikemeyer0's Avatar
not trying to be mean here but if you don't know what wire to use should you be making a wiring harness? But if i were going to do it i would start with finding out how many amps the wire needs to carry then that will tell you you gauge, less amps smaller wire, more = larger wire. The plugs if any are going to be the expensive part.
Old May 1, 2005 | 04:54 PM
4th Gear
thank you i dont no a great deal but my mate knows even less
Old May 2, 2005 | 01:35 AM
05LandRover's Avatar
time for you to do some research. hate to see a tim taylor on our hands.
everybody know what time it is?
tool time!!
Old Feb 2, 2007 | 10:47 PM
Tungus's Avatar
7th Gear
Having a diagram is just part of what you need to build a harness. You also need the wire length dimentionsand terminals. This requires a harness blueprint/schematic. This is a chart with actual routing and breakout locations measured out.
Harnesses are manufactured on a board (plywood) with nails/bolts to wrap the wires around and tape. Its a simple process when you have everything and all the information you need to put 1 together. The second easiest way is to reverse engineer an already built harness and fabricate a board to reproduce that harness. Sadly, this is only cost effective if you're going to massproduce that part. Its less hassle just to pay a lil higher price for a harness from the manufacturer.
I say: If you have the time and pateince.....and want to do it yourself, by all means. Do it.
Old Feb 9, 2007 | 04:23 PM
Tink's Avatar
This is scary....
lost in france
Defender
Apr 1, 2014 09:35 AM
chavhater
Sep 25, 2013 11:33 AM
MiniManiac
May 21, 2007 08:55 AM
asmcmillin
Apr 4, 2005 02:04 PM
yorzak
Jan 25, 2005 01:25 PM
