Oil running down loom to ECU
Old Sep 25, 2013 | 12:35 AM
chavhater's Avatar
From: at the side of the road wondering if I own the only Disco that doesn't like getting dirty
Default Oil running down loom to ECU
Hi two things is there any real benefit in chipping the ECU on a 2003 diesel 2.5 Disco 11 as ive been told that it improves the running and fuel economy.The other question was when the ECU plug was disconnected there was oil present on the plug, it hadn't got inside the ECU, but I'm concerned as to we're its coming from.
Many thanks.
Old Sep 25, 2013 | 12:44 AM
jafir's Avatar
I'm pretty sure the oil comes from the injector harness.
Most on this forum are in North America, and we didn't get the option for the Td5. You'll have better luck at aulro.
Old Sep 25, 2013 | 10:03 AM
There would be a benefit to chipping the engine, based on who does it and the type of driving you do. If you need more power, the process along with tubro/intercooler work would give you a big plus.
Old Sep 25, 2013 | 11:33 AM
jafir's Avatar
As new as the 2003 is, it should have a flashable ecu, so you can upload a map with nanocom or the like. (It doesn't hurt to verify the ecu part number just to be sure.)
Early d2 requires swapping a chip out or upgrading to the newer ecu.
Paul Grant
Aug 10, 2014 12:29 PM
lost in france
Defender
Apr 1, 2014 09:35 AM
Newfoundlandrover
Oct 2, 2011 06:51 PM
sheenalandi
Audio/Visual Electronics
Feb 9, 2007 04:23 PM
