If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
Battery Isolator is needed to keep the batteries seperated this also charges the primary (starting) battery first , then sends additional power to the secondary auxillary battery ... You can find the stinger brand ones for like $20 on ebay... I'm assuming you want a second battery mounted in the rear if so then summit racing has a battery relocation kit for $50 it includes wiring and a battery box ... Since this is inside the passenger compartment I'd suggest only using a gel cell (optima .stinger or Odessey type battery) incase of rollover the battery acid doesn't spill out ...
I also like to fuse or breaker both ends of the wire to alternator rated output , it's a safety incase you get a short on the wiring and prevent alternator damage or prevents a fire
Need Parts? paulgrant@mac.com, or 203-770-1699 willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
