Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Adding a second Battery
Old Feb 16, 2007 | 08:22 PM
Tink's Avatar
Default Adding a second Battery
Has anyone added a second battery to their 06 or newer Range Rover?
...just trying to avoid any pitfalls anyone else may have already encountered.
Thanks for any help
Old Apr 14, 2007 | 10:48 AM
fire1427's Avatar
Default RE: Adding a second Battery
Battery Isolator is needed to keep the batteries seperated this also charges the primary (starting) battery first , then sends additional power to the secondary auxillary battery ... You can find the stinger brand ones for like $20 on ebay... I'm assuming you want a second battery mounted in the rear if so then summit racing has a battery relocation kit for $50 it includes wiring and a battery box ... Since this is inside the passenger compartment I'd suggest only using a gel cell (optima .stinger or Odessey type battery) incase of rollover the battery acid doesn't spill out ...
I also like to fuse or breaker both ends of the wire to alternator rated output , it's a safety incase you get a short on the wiring and prevent alternator damage or prevents a fire
Old May 1, 2007 | 12:37 PM
Tink,
Just curious, why are you wanting a second battery, are you running a winch or just want some additional reserve?
Mike
Roverfanatic
Aug 14, 2015 11:26 AM
xoo00oox
Jan 11, 2013 06:23 AM
chiki
Jul 23, 2012 12:52 AM
dharch
Aug 25, 2008 11:03 PM
05LandRover
ROAMING WITH FRIENDS
Jun 9, 2005 04:22 PM
