Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
CD changer error
Old Dec 22, 2004 | 06:35 PM
igenov's Avatar
Default CD changer error
I got a 96 Range rover 4.6 and my cd changer reads "CDAC ER6", would anyone know what the problem is and how to fix it.
Thanks
Old Dec 24, 2004 | 04:38 AM
Lighting90's Avatar
Default RE: CD changer error
Most common problem I have heard is a stuck CD, or the mechanical part which moves the CD's to the playing area. Manily caused by a build up of dust inside.
Old Dec 27, 2004 | 12:07 PM
BrianH's Avatar
It might be an idea to contact LandRover and see if you can find out what error 6 means in relation to the CD Changer. Or pop down your local dealer and see if they'll be nice enough to tell you.
Brian
Old Feb 4, 2006 | 06:54 PM
rangeroverboi's Avatar
I got a 97 RR 4.0 and mine does the same thing. That error code means that the CD is upside down (to Land Rover); however we both know that we aren't morons and how to insert a CD right side up. Obviously, this has to be an error in the CD Changers reading of the CD. Try cleaning the pick up mechanism (black roller things) inside the changer, that helped mine somewhat. Also, try using a perfectly unscratched CD.
pixel
May 13, 2011 07:24 PM
JUSTINFO69
May 25, 2007 09:28 AM
cold_surfer
May 9, 2007 08:23 AM
cdparker
Sep 9, 2006 12:16 PM
asterix
Oct 26, 2005 07:23 PM
