Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
radio engine noise
Old Nov 1, 2007 | 06:14 PM
greenbayfan's Avatar
Default radio engine noise
Well here goes! I just bought a 98 disco not long ago. The factory radio was locked out so I figured instead of paying for the unlock code I would put in a new kenwood So I had a hook up for my sirius. Anyway, bought the adaptor harness, and had everything hooked up by a friend that works at a local sound shop. We got everything in and there is some crazy noise coming out of the speakers. So of course we start trying different options to knock out the noise....ground loop isolators, capacitors, grounded the engine to chassis, regrounded alternator, even went as far as running new lines for power and ground directly from battery. And no luck. There is a whine when the truck is off but when it is running the noiseheadache material! Anyone ever have this problem and get it fixed. I see alot of posts on here about radio noise but no posts from anyone who has ever fixed the problem. Everyone cant be driving around with a stock stereo. Please help! I think the next step is going to be a good set of plug wires that are insulated well. and hooking a spare speaker up to the headunit before the signal goes to the amp trying to rule out the amp.
Old Dec 27, 2007 | 09:26 AM
zerochills's Avatar
Default RE: radio engine noise
Had a similar problem (maybe not the same though). found it was pinched wires in the rear drivers side door. Straightened wires, checked for nicks and good to go. not always the ground. I ruled that out early on.
dogstarsix75
Apr 24, 2020 01:33 PM
greenbayfan
Mar 7, 2019 02:27 PM
southfloridadiscoII
Jun 28, 2009 11:03 PM
Discoverygirl65
Jul 24, 2008 08:57 AM
