Sponsored by: CARiD
Engine noise on radio
Old Jul 20, 2008 | 02:40 PM
Discoverygirl65's Avatar
Default Engine noise on radio
My 2000 Discovery started making a whining engine noise over the radio. Have no idea what caused it or how to fix it. Help please!!!
Old Jul 24, 2008 | 02:20 AM
wa3ra's Avatar
Default RE: Engine noise on radio
It is mostlikely alternator noise, especially if it rises and falls in pitch with the rise and fall of the rpms.
THIS DOES NOT MEAN THAT THE ALTERNATOR IS BAD!!!!!!!
The most common reason: your battery teminals are a little corroded. Clean all of the connections, protect them with a little petroleum jelly. This is probably all that you need to do.
Should this not work, have your parts store do a dynamic test on the starting and charging system to determine the weak part. It could be battery, alternator, voltage regulator, a slipping fan belt, or just a loose connection. It is usually something maintenance-related, and not one of the pricey parts.
HTH!
Bill
Old Jul 24, 2008 | 08:57 AM
This can also be caused by bad plugs and or wires.
How many miles on your truck?
dogstarsix75
Apr 24, 2020 01:33 PM
greenbayfan
Mar 7, 2019 02:27 PM
southfloridadiscoII
Jun 28, 2009 11:03 PM
greenbayfan
Audio/Visual Electronics
Dec 27, 2007 09:26 AM
