Defender Talk about the Land Rover Defender within.
Tires for Defender 110
Old Jan 29, 2009 | 12:01 PM
plgp00's Avatar
4th Gear
Default Tires for Defender 110
I posted this in the Tires section, but thought I might get more responses from the Defender crowd.
I am looking for thoughts on tires for my stock Defender 110 (1993 200Tdi).
So far I have boiled it down to either the BFG T/A KO's or the Bridgestone A/T Revos, both at a 265/75/R16 (Load Range D or E).
I know the BFG's are tried and tested on the Defender, but does anyone have any experience with the Revo's? I'm also open to any other suggestions for an all terrain tire that isn't too noisy on the highway.
Thanks!
Old Jan 29, 2009 | 03:20 PM
llesra's Avatar
Default RE: Tires for Defender 110
i have these on my disco and they make them in 265/75/16 now. very comfortable and good tread wear so far.
http://www.4wheelparts.com/Tires/Pro...t_pn=PCT560265
Old Jan 29, 2009 | 04:38 PM
discodefender's Avatar
I'm running mud kings on my defender. Made by bfg and same tread pattern as the bfg muds but way less expensive. 10k miles now and little to no wear as well as very quiet for a mud tire.
Old Jan 30, 2009 | 08:36 AM
plgp00's Avatar
4th Gear
Thanks for the responses -
Discodefender do you have 235/85 or 265/75 on your defender (assuming stock w/ no lift)?
I am considering a set of BFG MT's to leave up where I offroad, and a set of the BFG T/A All Terrains for the road/hwy trips up and back. But now debating sizes - height is the same (31" I believe) but its the width that's different.
Many thanks!
Old Jan 30, 2009 | 09:09 AM
I'm sure that they come in metric sizes also but I'm running a rovertym 3" lift with all the goodies and 35x12.50 on black steel 15x8s. I would recommend the tires for every day use. They are very quiet for a mud tire and wear very well. I only paid a little over $100 a tire. Traction is excellent. I would not hessitate to drive across the country with them.
Old Feb 2, 2009 | 02:12 PM
plgp00's Avatar
4th Gear
I'm also interested to hear opinions on the difference between going with a 265/75 versus a 235/85. Both apparently will fit a stock defender with no lift. The difference being the width of the tire. Some people argue for a narrower tire that will theoretically dig deeper through the top layer of soil and therefore provide better traction. Others I know say this is not true and that in fact a wider tire with it's greater area of contact with the ground will provide better traction. Thoughts anyone?
Old Feb 2, 2009 | 08:13 PM
yes. Get a lift. You will love it.
Old Feb 3, 2009 | 10:15 AM
You may also want to consider something fairly new and different that has come from Europe.
http://www.offroaders.com/reviewbox/...duct=334&cat=3
There are a number of trucks in the Solihull Society and they all say they are the best.
Old Feb 7, 2009 | 07:05 AM
Adz's Avatar
Adz
That 'Icelander'has exactly the same tread pattern as the Yokohama Geolander MT...
I use a Spanish made remold version on mine, Insa Turbo Sahara MT in 235/85/16 and can confirm they're excellent in the mud and on sand.
plgp00
Tires
Jan 31, 2009 10:37 AM
expeditionbrazil
Jan 15, 2007 05:32 PM
delboy38@gmail.com
Defender
Oct 5, 2006 08:47 PM
expeditionbrazil
Apr 22, 2006 11:10 PM
rhoadie
Aug 8, 2005 07:15 PM
