Defender Talk about the Land Rover Defender within.
Gears
Old Aug 3, 2012 | 09:31 AM
brian p's Avatar
Talking Gears
Hi all please can someone tell what is wrong with my defender other than get a garage to check it out. the problem is that my defender can't go into high gear only low gear it is only 4 years old it is a defender 90 it makes such a noise when i try and put into high gear any ideas anyone
Old Aug 6, 2012 | 05:57 AM
antichrist's Avatar
Can you be more specific? Which "high" gears, which "low gears"? High range or low range?
If it's 1st-5th in the main gearbox then it's probably either your clutch or baulk rings. Can you shift ok when it's not running?
RoverLand
Oct 18, 2006 09:55 PM
BMWLR
Sep 7, 2006 03:21 PM
extremetoy1
Jul 14, 2006 12:28 PM
Acer
Mar 29, 2005 07:27 PM
Acer
Feb 25, 2005 10:29 PM
