Defender Talk about the Land Rover Defender within.
Reverse gear problem
Old May 19, 2008 | 09:00 AM
dereklow's Avatar
Default Reverse gear problem
Hi all,
Recently acquired my first LR. Its a 1987 Defender 90 with a converted 300Tdi engine. When engaged in reverse, I get a consistent "clunking" noise. I'm guessing its the gearbox acting up but the mechanic reckon its the transfer box gears having "free-play" and needs to be looked at.
I've done some research on the internet and it seemed to be a known problem with the LT77 gearbox main output shaft not getting enough lubrication and eventually failing. I'm hoping I can get some advise, and hopefully save some $$$ avoiding fixing something that doesn't need fixing.
Thanks in advance.
colemtd
Nov 14, 2014 10:29 PM
Ozelote
LR2
Nov 14, 2011 04:05 PM
Livingintheskies
Jan 22, 2011 02:50 AM
cold_surfer
Mar 21, 2007 01:38 AM
db1047
Apr 27, 2006 08:10 PM
