Sponsored by: CARiD
Disco II gearbox noise when engaging reverse gear
Old Apr 21, 2006 | 04:06 AM
db1047's Avatar
Default Disco II gearbox noise when engaging reverse gear
My Discovery II TD5 automatic, 2002 model leaked transmission fluid yesterday while I was driving. The feedpipe came loose and I lost all my transmission fluid. Most of it drained out only after I stopped. We took it in to the LR workshop and they just had to tighten the feedpipe nut and refill the transmission fluid. When I got my Discovery back from them the first thing I saw was that the "Manual" and "Sport" mode lights were flashing on and off. After switching the ignition off and on again the problem went away. The second thing I noticed was that the gearbox made this clug sound when engaging the reverse gear. It does not happen every time though. It was not like this before the leak. The guys at my LR workshop say all the Discoveries makes this noise. I'm sure mine never made this noise.
If someone could please help, what is causing this noise?
Old Apr 27, 2006 | 08:10 PM
Default RE: Disco II gearbox noise when engaging reverse gear
It is not normal, I would consider calling a couple of other shops for a second option.
Mike
puraces123
Mar 2, 2024 10:12 AM
Big nic
Feb 11, 2013 03:52 PM
geoffreyworthington
Mar 26, 2012 11:41 AM
philo73
Dec 17, 2007 02:00 PM
