Defender Talk about the Land Rover Defender within.
thermostat and fuel gauge
Old May 29, 2011 | 02:48 PM
mac7's Avatar
Default thermostat and fuel gauge
Hello chaps just bought a defender (1988) which has had a 200tdi engine fitted ,
i have no reading on the temp or fuel gauge ...How should i test the instruments and eventually fix them ...thanks Mac
Old May 29, 2011 | 03:39 PM
First you need to make sure they are even hooked up, then you will need to trouble shoot from there.
Check the easy stuff first, is the temp gauge plugged in on the engine?
I am betting it came with a petrol engine and when they did the diesel swap they didnt hook everything back up or the ECU is not reading the inputs from the sensors.
Old Jun 8, 2011 | 05:52 PM
RoverMasterTech's Avatar
Im pretty sure they have a 5v generator behind the cluster somewhere, when this goes bad your gauges die
Rover_Hokie
Feb 2, 2014 03:52 PM
DiscoRover007
Jul 16, 2012 08:58 AM
JumPeR04
Apr 7, 2011 09:52 PM
Disco_Fever
Mar 31, 2011 09:46 AM
40ranger
Apr 7, 2008 12:20 AM
