Detailing Discuss detailing your ride within.
LIGHT SPRAYERS
Old Jul 25, 2008 | 11:03 PM
WALLACEJ's Avatar
4wd High
Default LIGHT SPRAYERS
THE HEADLIGHT SPRAYERS HAVE FADED BAD. IS THERE A PRODUCT THAT CAN GET THEM BACK TO THERE ORIGINAL BLACK COLOR? I HAVE A LR3 AND THIS REALLY STANDS OUT ON THE BUMPER. THANKS.
Old Jul 27, 2008 | 08:59 PM
fire1427's Avatar
Default RE: LIGHT SPRAYERS
http://www.showcardetailing.com/bw/
Old Jul 28, 2008 | 12:01 AM
WALLACEJ's Avatar
4wd High
THANKS, ILL HAVE TO TRY IT.
Old Dec 22, 2008 | 03:43 PM
getplaning's Avatar
I found a product called 303 Aerospace Protectant. It is designed for airplane cockpits that are exposed to high UV at high altitudes. When I first opened the container, I thought I had been duped into buying repackaged ArmorAll. But after using it, I have been amazed. It works as advertised,(SPF 30 for your stuff) and lasts.
Old Jan 14, 2009 | 07:43 PM
WALLACEJ's Avatar
4wd High
TRIED THE 303 PROTECTANT WITH NO LUCK AT ALL ON THE SPRAYERS. MAY BE A GOOD PROTECTANT BUT DIDNT DO ANYTHING FOR THE ALREADY FADED SPRAYERS.
Old Jan 14, 2009 | 07:47 PM
fire1427's Avatar
Try the Black Wow ???
Old Jan 21, 2009 | 08:21 PM
KarenCaren's Avatar
I just think you can put it back to the original color unless you repaint it with the color code of the original. It will always fade.
______________
Thepartsbin
Old Jan 22, 2009 | 07:20 PM
fire1427's Avatar
It's the same as the black wheel arches ... they fade and turn whitish ..
Old Jun 5, 2009 | 07:08 PM
exceldetail's Avatar
The BW is your best bet. It may take several applications for it to take full effect. Make sure all parts are thoroughly cleaned prior to using it.
newfrl
Freelander
16
Aug 27, 2020 06:55 AM
marlymarl
May 28, 2011 10:34 PM
agarabedian
Aug 14, 2007 03:59 PM
Brad S1
Oct 26, 2006 08:53 PM
Surfin Elvis
Jun 23, 2005 11:08 PM
