Detailing Discuss detailing your ride within.
wheel polishing
Old May 15, 2007 | 09:19 PM
rphotographer's Avatar
Default wheel polishing
Hello all,
I have a 1999 disco 2, with stock wheels, can theses wheels be polished?? if so what wouldI use on them.
Thanks
Ralph
Old May 17, 2007 | 07:32 AM
Default RE: wheel polishing
Use some brake cleaner to get rid of any heavy stains, then some rubbing compound to give them a good shine the 2 coats of a goos was and they will look really great and you'll find most road or brake dust won't stick as easily. There are also a couple of wheel polish compounds at the auto parts store.
Mike
Old Jul 19, 2007 | 05:24 PM
fx300's Avatar
I once polished my 300zx rims using some rough sand paper and finishing with the highest I could find (1000 or so) not sure on the #I just went to a local paint shop and asked for different types. It was a pain and I had to constantly clean them with a product called Mothers. The rims looked very nice every time I would clean them which had to be every weekend or so. I just believe the work to dothis isa bit too hard for me to ever do it again.Once again, plan on taking quite some time on this. If you can, buy a broken rim to try this.
Fabian
Old Jul 23, 2007 | 02:07 PM
tads's Avatar
Yikes! Sand paper on rims!!! Please be careful. Suggesting a practice rim was a GOOD idea!!
Most wheels are painted. Same type of paint (chemically) as on your vehicle. So fixing problems involves a compound. Or maybe just a simple polishing product which will have less abrasive value than your typical compound.
In any case it is hard, laborious work. Our shop charge per hour on most wheel, metal, and other brightwork polishing is near $100. That's expensive, yes. But ruining your wheels with sand paper or harsh abrasives and inexperienced hands is much more costly.
Just be cautious.
Old Jul 25, 2007 | 08:14 AM
fx300's Avatar
I was 18 or so at the time and do remember the rims looking nice once everything was done and over with, but must admit, very hard work!!! When I wasyoung,had lots of free time, andlimited income I was willing to try anything to make myvehicles look nice.Once again, I will never do this as my hands hurt for abit.
Fabian
Brownsville, Tx.
Old Apr 22, 2008 | 10:31 PM
KarenCaren's Avatar
I got this tip on really-useful.y2u.co.uk.
Here's an easy step by step method.
1. Step back a couple of feet and a bit off to the side of the rim then rinse the rim from about 8 inches away. Be sure to spray into the crevices and spray from different angles.
2. Spray the rim using a circular motion around the outside of the wheel and be sure to rinse the tire as well.
3. Put the sprayer wand down and apply tire cleaning solution onto the tire.
4. Using the pressure washer, rinse the whole tire this time from about 5 inches away.
5. Now spray the rim with rim cleaner generously, following label directions. Usually you'll have to leave it sit on the rim for a few minutes to lift the debris.
6. Rinse the cleaner from the rim from about 8 inches away with the pressure washer.
Note:
2. Always clean the rims before you clean your tires and only clean your wheels after you've cleaned your car body. You don't want all that dirt from the body washing back onto your clean rims.
2. Dry your rims with an old bath towel. Optionally you can apply a light coat of car wax which will keep your rims clean longer and make your next washing easier by reducing the amount of dust that will "stick" to your rims.
So, remember, cleaning your wheels can be done easily and quickly.
________________________
See my blog: Eco-Friendly Cars
dcarr1971
Feb 8, 2013 08:16 AM
nick731
Nov 16, 2010 12:25 PM
BENROVERN
Nov 5, 2007 09:19 AM
VB_Rover
Jun 30, 2005 10:48 PM
flowers
Apr 12, 2005 04:03 PM
