1996 3.9 Disco stalls and starting issues too...
Old Jun 2, 2010 | 02:29 PM
DiscoRabbit's Avatar
5th Gear
Default A small sign of hope...
After sitting out in the road for a couple months I decided to do a compression check to see if there were issues with the engine. One of my cylinders isn't getting compression. I tested it a couple times and followed the manuals instructions and from the looks of it I may have a bad valve.
To have it fixed out here I'm looking at $600+ so I've decided to go into the project blind as I've never dived this far into engine repair. I'm somewhat mechanically inclined as long as I have instructions.
For those that don't have it, be sure to download the instruction manual for the Disco, the link is in the forums on this site. It has been a great help to me. I'll post more over the coming weeks as I get further into this project.
This job is so much fun I decided to write a blog if you're interested in following along: http://thelandroverproject.blogspot.com
Old Apr 23, 2012 | 01:14 AM
alrodkenya's Avatar
5th Gear
Lightbulb
Originally Posted by DiscoRabbit
I've gone through the threads, searched the internet, read the manuals, and replaced parts and still having issues.
Here's my vehicle:
Land Rover Discovery I
Year: 1996
Engine: 3.9 V8 Petrol
Transmission: Automatic
Miles: 74,000
* British Spec, right hand drive.
History:
I bought it off a local that was going to part it out but decided not to since it was in such great condition...and it is. I looked in the records and found that the last dealer service was back in 2004 when it had about 62,000 miles on it. So that means for the last 6 years its only been driven 12,000 miles. I drove it for about a week and then started having issues.
What it is doing:
I start it up and drive away...almost immediately when I hit the accelerator it kind of lags in power and almost stalls. To keep it running I've found that I can keep my foot on the gas and brake or drop it to neutral as required as I decrease in speed, usually keeping RPMs around 2-3000. This will prevent the stalling while I'm driving.
However, when I stop and let my foot off the gas then it will stall and won't start up again. Cranks, but no starting...at least until I let it set for awhile.
After about 15-20 minutes, I have to keep pumping the gas pedal until I can coax it to start...sometimes it will, sometimes it won't. All the issues are very intermittent and I have not noticed a difference when its hot or cold outside. Although time that the vehicle is running is sometimes a factor. However sometimes it is difficult to start cold, but will still start none the less. It is after its been running and I turn it off that the not starting is often the problem.
I just tried this today: Started engine, no problem. Let idle for a couple minutes then hit accelerator a couple times to see if the idle would fluctuate, it didn't. Then I put it in drive, rpms fall as they should, but as soon as I hit the gas, it hesitated and rpms drop. It chugged a bit and I got moving. I let it idle down the street a bit and as soon as I would hit the gas though, it would hesitate and almost want to stall. I continued on doing the accelerator/brake method to keep rpms up while driving to get it up to normal operating temp. Got back, turned it off and it cranked right back up. However there is hesitation on hitting the gas pedal. Hmmm....
My initial guess, fuel or ignition problem. I heard of the crankshaft position sensor going bad...however, this vehicle does not have one (according to the dealer and I've looked all over for it).
So this is what I've replaced so far:
- Distributor
- Rotor
- Plugs and Leads
- Oil
- Fuel Pump
- Fuel Filter
- Mass Air Flow Sensor (MAF)
> I spoke with a local dealer that uses Auto Logic for diagnostics and they said that AL is very limited to the codes it will read and is unlikely to pick up the engine codes. Anyone ever hear of that?
> Check engine light illuminates for a millisecond during the lamp test and then shuts off...it seems it would stay on longer, most of the time I miss it coming on its so fast. However, it has never lit up at anytime.
> Fuel Pressure check is approx. 2.3 bar at the fuel rail which is normal according to the manual.
> The fuel pump always turns on whenever I go to start the vehicle, even when it just sits there and cranks but does not turn over.
Here's what I'm going to try next:
> Compression check
> Fuel Temperature Gauge
> Throttle positioning sensor
Any comments/recommendations? This is getting kind of expensive. Thanks.
On a side note, I do get some blue exhaust while idling and occassionally while driving. I've heard valve stem seals are often an issue and I didn't think it would be related, but I'm adding it in here just in case. Also, the midsection of the exhaust has a hole in it.
hi im new to your forum ,if you haven't checked check if the ignition coil is getting hot or your fuel pump is heating
Old May 3, 2012 | 11:24 AM
abriels's Avatar
6th Gear
I am having the same problem with my 98 Disco. I know my MAF is bad and I am replacing that, but could that be the problem to my starting and stalling problems, its very intermittent.
Old May 4, 2012 | 11:55 PM
alrodkenya's Avatar
5th Gear
are you still having this problem ,i posted a simmilar problem but it was solved .reason im asking is in the process i gain a lot of knowledge on this vehicle (im a mechanic in kenya , but this one had taken me for a ride ) .if you still do have the problem pleas postsome details wiil try and help deal with a lot of problems here that r not very common in other countries regards
Old Jan 31, 2018 | 07:11 PM
Joris Allard's Avatar
Hi guys,
i have the same problem with my discovery 1 1996 automatic. It was initially good working and while I was driving the car it stopped unexpectedly. After that I couldn’t start again so I wait for a while and could start it again. I have now the same problem every time. It start properly, i can drive it but after few kms it’s stops and then I have to wait to start it again. Do you have any ideas of the problem and how I could sort it out?
Old Jan 31, 2018 | 11:07 PM
robertf's Avatar
Originally Posted by Joris Allard
Hi guys,
If you live in North America you should probably start a new thread. The 96 this one is about is a different EFI system.
Old Feb 1, 2018 | 12:14 AM
I actually live in australia
jaffadutch
Mar 29, 2014 04:00 PM
jjordan0391
Dec 12, 2013 04:40 PM
Summitdog
Jan 19, 2012 11:11 AM
benflynn
Dec 20, 2007 05:47 PM
tover
Sep 20, 2005 11:57 PM
