1997 discovery timing issue I think
Old Oct 8, 2010 | 11:48 AM
derek010's Avatar
6th Gear
Default 1997 discovery timing issue I think
It's a 1997 discovery with what seems to be a timing issue. Before it died there was no power and it almost led me to think fuel pump. It has the electronic ignition but I don't know how to adjust it. It will run on small doses of starting fluid but sounds like its running on 4 cylinders then backfires thru the intake. It cranks over like it's missing or theres no compression. I haven't done a compression test yet, will this weekend but I'm convinced it's the timing. How do I adjust it? It has around 120,000 miles. Does anyone know where I can download a manual on this thing? I wish they had the diesels over here, what were they thinking not bringing them?lol. Something this size and still 28mpg, they would be more cost effective than a hybrid....
Old Oct 8, 2010 | 12:41 PM
Jull's Avatar
You can't ajust timing with the electronic ignition. Have you done a tune up? Is there fuel pressure at the rail? here is the link for Rave manual:
http://green-oval.com/joomla/index.p...d=13&Itemid=29
Old Oct 8, 2010 | 01:08 PM
NiteTrain's Avatar
yeah check fuel pressure first
edit: with a fuel pressure gauge not a air pressure gauge
Old Oct 9, 2010 | 05:24 PM
And when did you last replace your fuel filter?
A5scott
Jul 11, 2015 07:25 PM
Martin Rodriguez
Feb 25, 2014 08:55 PM
Snafu / Disco Fries
Jan 28, 2011 01:42 PM
lipadj46
Aug 19, 2009 06:11 PM
