rattle on cold start up
Old Dec 8, 2011 | 05:09 PM
Johntom's Avatar
3rd Gear
Default rattle on cold start up
Hi
my tdi has an engine rattle on cold starts which disapears after a few minutes. there does seem to be a shuddering as well. How do i tell if its an injector or valve clearance issue, or could it be something else?
Old Dec 8, 2011 | 07:21 PM
What weight motor oil are you using?
How long have you owned the truck?
Old Dec 9, 2011 | 10:13 AM
Is the noise in the engine compartment or under the truck?
Old Dec 10, 2011 | 04:38 PM
Johntom's Avatar
3rd Gear
Hi
I haven't owned the car long hence, I don't have a clue what oil is in there. What grade would you recommend (150k) ?
And yes the noise is in the engine compartment, it's not terrible it just seems louder with more of a rattle for the first few minutes. It is also just on tickover when it's noisy, if it's revved closer to 1000rpm from cold there is definitely less of a rattle.
Old Dec 10, 2011 | 04:47 PM
Without knowing where you live it makes it hard to know what oil to recommend.
Old Dec 10, 2011 | 11:01 PM
Johntom,
You may wish to take advantage of the free download of the RAVE, a collection of Rover service and owners manuals. Many times it can guide you without having to wait for some one to jump in and reply. People are on this forum from around the world, so time zones also play a part.
To whet your appetite for Rover knowledge, here is the oil page from the owner's manual. Many users enjoy using a diesel rated oil like Shell Rotella because of extra detergent properties that help clean up an engine that has missed changes in the past. Won't re-grow metal, but will clean up some gunk.
File Type: pdf
Crash_Control
May 29, 2021 12:27 AM
dynomite
Feb 14, 2015 04:33 PM
snads
Dec 6, 2014 02:42 PM
pkppunk
Jan 26, 2013 07:05 PM
brettmasters26
Nov 25, 2011 07:40 PM
