Starting Issue
Old Dec 9, 2011 | 10:00 AM
GSmith's Avatar
4th Gear
Default Starting Issue
Hello, I need a little help figuring out an issue. I have a 98 disco with 168k on it. I am seeing codes 1193, 0451, and 1508. Here is what is happening: She will start fine and run fine for a few days, then go through a phase where she either won't start or will stall out soon after putting her in gear and then not start again. To make it start, all I have to do is unplug the main harness from the fuel pump and plug it back in. I know that sounds strange but it consistently works. FYI, the fuel pump is new, the fuel relay is fine, and the idle control valve has been pulled and cleaned (I have a new one to install when/if the time comes). Also, after running about town for an hour or so, the idle will get rough, almost stall out. I welcome any educated opinions on how to fix this, thank you.
Old Dec 9, 2011 | 10:09 AM
1508 is an idle speed control unit failure, have you cleaned both the t/body and the IAC?
1193 is a 02 sensor heater circuit open downstream, have you ever replaced all 4 02's?
451 is a evap control system pressure sensor out of range.
How do you know the relay is OK, there are 3 separate relays in that one black box and you can only determine if all 3 are working with an OHM meter.
Old Dec 9, 2011 | 10:46 AM
GSmith's Avatar
4th Gear
I have not cleaned the throttle body, just the IAC. I have not replaced the O2 sensors yet. I opened the relay box, tested each and observed them working. I thought 0451 was a Fuel Tank Pressure Sensor Signal Error Fault, is that saying the same thing?
Old Dec 9, 2011 | 12:07 PM
Same thing on the 451.
Can't say the 02's will fix your issue but you are way past do for them.
Old Dec 9, 2011 | 08:12 PM
cvet78's Avatar
Default Disco starting and running problems
I had the valve cover gaskets replace and while they had it it would not start for them and they said, "they unpluged something on the firewall passenger side and it started. After I got it home I went to start it and show it to someone who wanted to buy it and it would not start. The next day it started. I drove it and while driving it it stopped running, I pulled off the road and it started back up. Drove it home and after parking I want to move it and it would not start. Later I went out and it started. Please any help I can get it's a 98 disco.
Thanks
Old Dec 9, 2011 | 10:02 PM
GSmith's Avatar
4th Gear
I agree on the O2 sensors Mike. My best guess on the situation is that I should go ahead and replace the IAC valve and get the adaptive memory reset. Does that sound unreasonable to anyone?
Old Dec 10, 2011 | 09:40 AM
If they unplugged something it was probably the inerita switch on the passengers side of the fire wall.
Old Dec 10, 2011 | 02:18 PM
threalassmikeg's Avatar
When was the last time you replaced the fuel filter?
Replace the fuel filter if not done receently, and hook up a fuel pressure gauge.
fuel pressure should be around 38 psi. If it starts to drop off or is low you need a fuel pump.
Old Dec 13, 2011 | 10:47 AM
cvet78's Avatar
Smile Starting and running issue
Mike, I had came to the same conclusion that you had posted inerita switch. Purchased one off E-bay for less then $20. Will let you know if that takes care of the problem thanks.
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
chargersfan
Jan 6, 2009 06:08 PM
alsuch
Apr 20, 2008 09:09 PM
rravenn13
Aug 18, 2007 10:04 PM
Rob84
Feb 7, 2007 08:49 PM
