Defender Brake Upgrade on D1
Old 05-08-2012, 02:25 PM
calebbo's Avatar
Default Defender Brake Upgrade on D1
So I remember hearing about how we can beef up our brakes with the defenders calipers. Now I don't know much about defenders but if I get the front brake calipers off of a 95 defender 90 will they work for the front and rear of my D1?
Old 05-08-2012, 02:50 PM
fishEH's Avatar
Front yes. D90 and D1 have the same rear brakes already.
Old 05-08-2012, 03:01 PM
calebbo's Avatar
Sweet thanks, I'll write up and take pics once I get the parts saturday.
EDIT:
oh are the rotors changeable also? or can I keep the disco rotors and still use defender calipers?
Old 05-08-2012, 03:07 PM
G Reeves's Avatar
Have to admit I have never herd of putting breaks from defender (90) onto a disco 1. I have done alot of rear axle conversions from discovery onto earlier 90's as they had drum breaks.
Old 05-08-2012, 03:13 PM
antichrist's Avatar
No, rotors aren't the same.
You need D90 front calipers and front rotors.
You also need to make new hard lines between the flex line and caliper (though some have had luck bending the Disco lines, I'm too OCD for that).
I have a bunch of photos from when I did mine in my photobucket album:
http://s577.photobucket.com/albums/s...s/brakes-hubs/
But I did all new brakes, including MC and SS flex lines.
Old 05-08-2012, 03:15 PM
wheelgarage's Avatar
You will need the D90 rotors, those are vented disks. Just get new ones since they are cheap anyway. Rebuilding the calipers are easy and straight forward....
Old 05-08-2012, 03:27 PM
calebbo's Avatar
Are the wheel bearings different or the hub seals? Still RTC3511 right?
Old 05-08-2012, 04:05 PM
Jake1996D1's Avatar
Justin can get this kit for around $300
includes new front rotors and calipers
Nothing else is different bolts up and you have to put a little bend in the hard brake line to get it to fit.
Old 05-08-2012, 04:42 PM
antichrist's Avatar
I forgot to mention you also need new caliper hardware, the pad retaining pins and springs are longer.
Old 05-08-2012, 09:36 PM
I didn't know that. The last kit I got had the longer pins.......
Quick Reply: Defender Brake Upgrade on D1
