Engine Performance Upgrades??
Old Jul 8, 2004 | 03:51 PM
Pyro's Avatar
Default Engine Performance Upgrades??
I recently aquired a 97 Disco (Freebie)and was wondering if there are any basic engine mods I can do that will enhance power such as air filter, exhaust, etc....</P>
I'm mainly familiar with American cars such as Fords and Chevys but I know SQUAT about Land Rovers. It hasa V8 so I'm assuming I can do the basic stuf like a K&amp;N filter and free flowing mufflers and the like. Any suggestions? Brands? </P>
Also, any info on suspension lifts are welcome. Ideally, I'd like to lift it enough toput 33" tires on there. </P>
Old Jul 14, 2004 | 03:57 AM
Lighting90's Avatar
There are several ways to improve performance, though it depends what you want to improve.</P>
One is to fit a larger intercooler, Allard in the uk are a good starting point for that, also getting a new chip if yours has one fitted. K&amp;N filters are also a good start as you know. </P>
With regard to lift, Bilston shocks seem to be a good place to start. </P>
Old Jul 14, 2004 | 12:27 PM
Pyro's Avatar
</P>
Unless I'm missing something major, my Discovery doesn't have a turbo or supercharger so it shouldn't have an intercooler.?</P>
I think I'll just start with free flowing mufflers and a K&amp;N Filter for starters. </P>
Old Jul 14, 2004 | 06:22 PM
Lighting90's Avatar
Silly me, so use to people driving the tdi's over here.. <IMG src=smileys/smiley8.gif border="0"></P>
Old man emu do a lift I understand as another option for you... <IMG src=smileys/smiley1.gif border="0"></P>
</P>
Old Jul 20, 2004 | 04:33 AM
Lighting90's Avatar
Here is a website for you to have a look at, http://www.scorpionracing.co.uk/OFFROAD/offroad.html</P>
They cover a range of modifications that you can either try and get from them or maybe find more local.</P>
Hope it is of help. <IMG src=smileys/smiley1.gif border="0"></P>
Old Jul 25, 2004 | 11:47 PM
dirtryjim's Avatar
3rd Gear
i wouldn't run the k&amp;n ,hotwire mass airs don't like sucking oil fumes.i would start with a borla or nrp exhaust &amp; high flow cats.superchip sells a chip but its $500.add magnacore wires.you can even look for a 4.6 from a 96-02 range rover when your 4.0 gets tired</P>
for your lift i would go to http://www.expeditionexchange.com/index.htm run ome 764 springs in the front &amp; 762's in the rear w/ 1" spacers&amp; EE backing plates for shocks run ome n73's in the front &amp; n76's in the rear,you will have to fab new lower mounts or use n44's &amp; EE shock mounts.you may get some driveline vibrations too, some do some don't, a dual card. front shaft will usually fix that.i would replace the roto-flex rear driveshaft with a u-joint one from a discoII or one of the kits.http://www.rovertym.com/also sells 3" springs and offsett arms.and with 33's you will need gears the only place for them is http://www.greatbasinrovers.com/</P>
Old May 10, 2012 | 04:10 PM
RoverMasterTech's Avatar
That's right, I just bumped the oldest thread!
Old May 10, 2012 | 09:19 PM
Nice one!!
Old May 11, 2012 | 08:13 AM
thebloody's Avatar
Holy sweet Jesus, this thread is older than my truck!
Old May 11, 2012 | 08:19 AM
And shows that people have always quested for the holy grail of increased reliability, neck snapping acceleration, and 1/4 mile times in the 10's.
Of course, since my D1 can do 0-60 in 3.2 gallons, I'm good.
