Engine Questions
Engine Questions
Well I have a 1998 Disco with 250K original miles and it runs great but…..when the weather is warmer (above 50 degrees) the engine will tick/knock and I can not figure out why to would do this?
I have noticed that the electric fans do not engage when it is warm out EVER and do not engage when I use the A/C? I am now living in Bend Oregon and have contacted a place called Bend British that is going to take a look to see if maybe he can pinpoint the issue. He also said that he can replace the engine with a good used lump.
The question is what advice do people have with replacement engine vs rebuild vs swapping in a diesel from a MB or something like that? My engine runs great does not burn oil, or over heat…unless I run A/C and it is 110 degrees outside. The knoc/tick is a terrible noise that I have been driving with for over 20k miles but now I want to do something about it.
180 T-stat warm enough?
I am thinking of replacing it with a 195 T-stat later; any down side to running in the 180 range until then? Is that warm enough to normalize all the engine management functions?
Hanomag (02-25-2015)
I have tried the 15w 40 oil in the past but it did not make a difference. I am currently using a 10w40 Dino oil. I am going to be installing some working electric fans pretty soon. Not sure if it would fix the knock but I suppose that even if I get a new engine I would need working fans anyway.
