Gears
#21
thanks, saw that. I was thinking that since trutracs allow me the ability to use the stock axles, I'd be better off. Easy and cheap and I recently accumulated a stockpile of spare axles/cv. took advantage of free holiday shipping on the fleabay... those high dollar hds will be plan B. Plan c involves, learning to drive.
plan d involves =
still working on that one
plan d involves =
#23
#25
#26
Well finally took the time and figured it all out. I'm running 3.90 ring and pinion and I'm also starting to suspect that there's a true trac in the front but I'm not positive. Come spring and once I have some time I'm going to take the axles apart and see what's going on in there
There's an easy way to tell what you have in there, here's what I think it is.
Put the TC in Neutral and jack up the rear end so the tires are off the ground.
For stock gearing the driveshaft should turn 3.54 times for every one revolution of the wheel.
So turn the wheel and count the number of times the driveshaft spins.
Somebody help me out if I'm mistaken on this.
#27
#30
